Chargers
  • #31
    Chargers
    if i was to buy from tecnobots would these leads be the right ones
    http://www.technobots.co.uk/acatalog/Online_Catalogue_Charging_Leads_2.htmlhttp://www.technobots.co.uk/acatalog...g_Leads_2.html
    top 2?
    alex
    • #32
      Chargers
      as long as you dont mix up positive and negative you can do whatever you want with the leads. However for a good detection of delta peak on the nimh/nicads i recommend as little in between connections as possible.
      2 leads with the proper connectors on either end (thats what i meant with other side) gives the best charge results. So 2 banana plugs, 2 leads, 1 tamiya connector for your nicads or nimhs. You could als get a female tamiya connector and put it on your SLA.
      • #33
        Chargers
        top 2?
        That would do it.
        • #34
          Chargers
          Those would be fine. Quite cheap too for made leads.
          • #35
            Chargers
            Reveving old threads
            Im currently looking for a charger capable of handling Lithium, NICD, NIMH and PB, and came across the http://www.amainhobbies.com/product_.../20720Hyperion
            • #36
              Chargers
              this is the one i have think it does all those battery types, charges and discharges (you would need to buy some leads with it though)
              http://www.technobots.co.uk/acatalog/Online_Catalogue_Universal_Chargers_28.htmlhttp://www.technobots.co.uk/acatalog...argers_28.html
              its this the - Pro-Peak Sigma AC/DC Charger to 5A (third one down)
              alex
