Thats the setup in Little Hitter but we use 30V motors out of NuTool Drills, not sure maybe someone else can confirm but Id expect about the same performance out of the DeWalts ones so it should drive very well indeed with the right gear ratio.
The gear box has 3 settings,so im hoping to be able to play about until I find the one i like.I think the ratios are,450/1500/2000.I will be driving a small gear of 18 teeth and then on to a larger gear of 40 teeth which will drive 100mm blue tyers.Im hoping to end up with a medium speed but powerfull pusher.The dewalt motors i guess should be more powerfull looking at the torque specification of 56nm dewalt against about 20/30nm nutool?.. I havent got a clue i realy,i just ask you guys!
