Chargering Nimhs
  • Chargering Nimhs
    hi all
    brought 2 8.4v 3300mah nimh battery packs. not chargered them yet, but the charger i have been using for my nicads is an Ansmann acs47 which i think can also charge Nimhs.
    has anyone had expierence with this charger, and therefore knows if it will charge Nimhs?
    also i i saw what looked like a very similar one on ebay which could charge both but for use with 1400mah-3000mah, just wonder if my current one does charge nimh whta would happen if it only went up to 3000mah, when my bats are 3300mah?
    thanks alex
    (Message edited by psycho fling on June 17, 2007)
    Chargering Nimhs
    Google search .......
    The ACS 47 however is a different beast - its a powerful, good charger.
    It has 3 settings:
    1AMP - will take approx 3 hours to peak a 3000mah pack
    2AMP - will take approx 1.5 hours to peak a 3000mah pack
    4AMP - will take approx 45mins to peak a 3000mah pack
    Generally, peak chargers can take any mah pack, so 3000mah are no problem, as are 3300s etc..
      Chargering Nimhs
      if i find out that it is a multi charger does this mean it will charge nimhs? hence multi
      alex
        Chargering Nimhs
        Jeez Alex .....Google ... Search
        Ansmann acs47 nimh
        http://www.fusionhobbies.com/ProductDetails.asp?ProductCode=ACS47&click=2http://www.fusionhobbies.com/Product...=ACS47&click=2
          Chargering Nimhs
          thanks woody i did actually google it but i get nowhere or just dont put enough effort into it
          thanks alex
            Chargering Nimhs
            What about the instructions that came with the charger , or any further products you buy in the future ?
              Chargering Nimhs
              hope you dont mind me jumping in the thread, i brought some battery packs today for my first fw, they are 7.2v 3700mah, they say nimh on them and im charging these with my old fast propeak chargers from my radio controlled car days years ago, are these ok to charge with? batteries arnt my thing
              (Message edited by ady on June 18, 2007)
                Chargering Nimhs
                erm.. instructions somewhere around but dont know where the reason for me asking
                  Chargering Nimhs
                  Which Pro Peak one of these?
                  http://www.active-robots.com/products/power-supplies/battery-chargers/o-ip2500vp-manual.pdfhttp://www.active-robots.com/product...ers/o-ip2500vp -manual.pdf
                  http://www.ripmax.com/Images/PDF_Files/Instructions/Chargers/Pro_peak2500_Manual_LR.pdfhttp://www.ripmax.com/Images/PDF_Fil...eak2500_Manual _LR.pdf
                  I suspect the answer is yes ...no matter which model you might have.
