Hi Everyone
Ive decided to upgrade the drive on Hells Angel, getting rid of the drill motors and electronize speedos and replacing them with Victor 883 speed controllers and team Whyachi motors. However, before I do this I need to know a few things:
A: do the victors require a signal booster (PWM Signal Driver) if Im using a Skysports 6 radio ? or, for that matter, does it need one if you use a spektrum ? (another possible upgrade)
B: Ive seen a lot of these whyachi motors but I dont know which would be best for me, all the stats mean very little to me
C: is the mounting block for those motors ali ? if so, can I just get them welded to the base ?
Thanks in advance
David
Thanks in advance
David
