Welding help
  • Welding help
    hi all
    i have nearly finished the cutting of my box section, and once it is complete done i intend to weld it.
    unfortunatly i cant weld so would require a talented roboteer to do it for me. Any offers?
    this may seem like a familar post, but im just see what offers are still open
    also before getting it welded would all the holes need to have been drilled?
    thanks alex
    Welding help
    Youre always welcome over here for a weekend of robot building.
    Unfortunatly its in Belgium...
      Welding help
      well its alot easier to drill them as single pieces of box as it can be difficult to get into places when its all welded up but if all the holes are in simple places to get to you could weld it up first. i always drill first. you should be able to find sombody close that will weld it up for you.
        Welding help
        If they are lightening holes then you can drill them anytime. If they are for positioning components I would do it afterwards as welding can slightly warp box section and things can be put slightly out of alignment.
          Welding help
          lightening holes, I normally cause them with my arc welder !!!!
            Welding help
            You get very good at filling them in when you start out
              Welding help
              Alex, I will happily weld it for you. But you will have to let me know how it was to go together etc and when you need it doing for. Also have to bring it down or see me at an event.
                Welding help
                ill email you ed, thanks for the kind offer
                alex
                  Welding help
                  Isnt my offer just the same, except the distance? (but Babs and me offer free lodging)
