Pneumatic flipper systems
    Thanks guys.
      Also, what rams and valves would be good for a bot with a T-Minus style flipper (cause thats what Im leaning towards right now)? Ive looked up some stuff on Technobots, and theyve got pretty awesome stuff, but I cant go overseas from Canada to the US or UK, and E-Bay is pretty much out of the question at the moment.
        keep the weight down, you want 1 ram not 2 and for a fast flipper i would recomend a 3/8bsp or 1/2bsp valve
        you doing low pressure or full pressure?
          Full pressure there, Kenny. And yes, I like the 3/8bsp ram. Im going to research if I can find any of them near Toronto.
            so for your bot you going full pressure? i wouldnt if its your first bot, theres some serious power and speed in full pressure, if you wanted to go full pressure go for 1/2bsp has the valves are easy to get, plus more flow
              Thanks very much. Ill look up some stuff tonight.
                Did someone build a custom 3/2 HP valve? If so, are there plans available?
                • #23
                  Yes, Woody did build a balanced 3/2 FP valve. There are 2 in use. 1 in Tough As Nails (since 2002) and one in Woodies own machine KaPut.
                  Also, I have rebuilded in the past a LP 5/2 valve to be used @ FP. That went from solenoid activated to RC servo steered.
                  Woody improved that idea and now we have the grand total of 4 5/2 valves that can control FP with the solenoid.
                  Unfortunatly, all of those need LP to be activated.
                  • #24
                    Does that mean that they end up being heavy? Are there plans or pictures online?
                    • #25
                      Youll have to ask Woody on the plans.
                      And heavy. No improvement over a Burkert, unfortunatly.
                      Unless the servo controlled idea is used.
                      • #26
                        Thank you
                        • #27
                          http://www.robowars.org/forum/album_pic.php?pic_id=1422http://www.robowars.org/forum/album_pic.php?pic_id=1422
                          http://www.robowars.org/forum/album_pic.php?pic_id=1420http://www.robowars.org/forum/album_pic.php?pic_id=1420
                          http://www.robowars.org/forum/album_pic.php?pic_id=1421http://www.robowars.org/forum/album_pic.php?pic_id=1421
