Valves
  • Valves
    I have just started to build my flipper robot and Im not sure how to switch on and off the solenoid for the valve by radio control. What would be the best way to do this??
    Thanks
    Will
    Valves
    an electronize rc switch from technobots is the easyest i found
      Valves
      edgehog uses a servo and microswitches for his axe valves.
        Valves
        Thats kinda what im doing only mine sux in that test frame with that flipper on it. i have a servo that presses a switch that activates the solenoid from a car boot lock that presses a valve.
          Valves
          Its been posted before ......but here it is again for those new to pneumatics.
          http://www.teamdavinci.com/understanding_pneumatics.htmhttp://www.teamdavinci.com/understanding_pneumatics.htm
            Valves
            Will you have e-mail
            Trev
              Valves
              ill be trying this pneumatic stuff in a few weeks just trying to get cheap parts for it at the moment.
