Fuses
This topic is closed.
  • Fuses
    hi all
    in a feather weight, to be able to compete does it need a fuse? also i bought a power light from technobots but now need the lead, i cant see it on the site does anyone either have to sell or can see them on technobots?
    cheers alex
    Fuses
    It doesnt need a fuse, but to protect precious speed controllers if they dont current limit it is not a bad idea. Fuses are cheaper to replace than speed controllers.
      Fuses
      do electrolize do this?
      cheers alex
        Fuses
        try maplin or halfords, or the scrap yard, there are plenty of fuseholders under the bonnet.
        (Message edited by jamesb on February 11, 2007)
          Fuses
          Dont electrolize have a built in fuse ? The ones I have do
            Fuses
            I am thinking of fuesing the lead supplying the led,im worried that if either the led or lead get traped or damaged this will result in a short circuit across my 24v batt supply.Melting the thin led cable or takeing out my main fuse.both not nice things to happen.
              Fuses
              I might aswell do it then it will only cost under a pound from technobots
              thanks for the help
              alex
                Fuses
                I put two resistors in each wire going to the LED at the speed controller battery connector, that way a short with either or both wires would result in no damage execpt to the LED, depending on the fault.
                  Fuses
                  I use an 80A fuse directly after the link. Doesnt cost much, and it saves my lipos just incase i draw too much current.
                    Fuses
                    or just use the fuse as the link?
                      Fuses
                      as i have many, many times (sorry pete )
                        Fuses
                        at colchester we had a little trouble with block of wood
                        on the second day a fuse seemed to go, this has happened before and is the one on the speedo now both speedo fuses have gone once. what might be the cause? we cant go on changing the fuses ever event
                        alex
                          Fuses
                          What rating are the fuses you are using?
                            Fuses
                            Perhaps you could look at circuit breakers for protection which you then dont have to replace?
                            You could get temporary-set models which will self-reset after a certain time, thus if you experience a current spike during a battle for whatever reason the circuit breaker may cut out for protection for a few seconds and then resume conducting afterwards, cutting out again if the current resumes to be at sufficiently high levels.
                            Only really a suggestion for an alternative to fuses as opposed to a suggestion as to the cause of your high current/too low rated fuses woes. Without a good enough description or first-hand viewing its hard to diagnose problems like this.
                              Fuses
                              The motor makes a good fuse !
                              Seriously though, in an ultra-competitive fight you want all your bot can give you. Consider if you need the fuse or not as the chances are all the expensive parts will have gone pop before the fuse has a chance to react anyway.
                              Just my 2 cents !
                              Ed
                              http://www.teamstorm.comhttp://www.teamstorm.com
