How to secure drill motors?
This topic is closed.
    image wont upload, ill just e-mail it you tonight.
      Grant Im interested , send me the picture as well
        Im also interested, so could I possibly ditto Alis request please?
        Cheers
          I am also interested, could you please send me the pictures as well
          thanks
          Will
            Grant, There is now a size limit of 800x600 pixels for profile pictures, to save disk space.
              Im also interested.Cotld you send it to me aswell please?
              Sorry for any inconvinience :S
                see my profile for pic of my mounts.
                Ive never had a motor break using these, or gearbox, other than through putting too much power through and breaking the gears.
                • #23
                  all i can say is beauty has these james I had no problems untill mario got his hands on beauty
                  i have broken 6 g/boxes in the last 8 fights
                  Johnno an I think my problems the ram fireing so i blame Mario but we are working on it daily!!
                  together we will get there or goto bosches
                  • #24
                    hi john,
                    can i offer 2 suggestions to help preserve your gearboxes, I assume it is the plastic rear plate on the gearbox that holds the motor on that is your problem??
                    1- use a second, or move your current, large hole mount (the one for the rear of the motor) to the other side of the ferrite ring (you need to slide this off the motor and replace later) which gives more support at this point. use screww/bolts and thin ali or steel tube as a long washer to brace this area for extra rigidity.
                    2- drill holes in your wheels tire. assuming they are solid rubber, putting holes across the tread creates squishy spokes in the rubber. these can be tuned with a little trial and error to give support running normally, but under the high loads of flipping, will deform and allow your chassis to rest on the ground, taking the loads away from your gearbox.
                    hope this helps
                    james
                    • #25
                      hmm well its on 10mm poly floor atm and ive moved the second mount where johnos just bolts a perspex 10mm plate on to gear box as i say we wre working on it
                      the metal 3 prong bit keeps snapping and locks g/box up but in for another test tom at Robots live
                      • #26
                        Hi James b
                        could you give the dimensions of the motor mounts that you sell,
                        cheers alex
                        • #27
                          John, Beauty came a long way. And youll keep upgrading her untill nothing breaks anymore.
                          From a bufferless 25mm bore ram to a buffered 60mm bore ram.... (not a ram build by me, but by Inventor)
                          That means you came from 250 kg of slow force to 1412 kg of faster action. And that all for less weigth.
                          I wonder why things break?
                          • #28
                            Mario beauty2 is only half made
                            but yes all your fault
                            ps shes good now
