Featherweight Database
    Robot: Super Dinky
    Weight: 2kg
    Speed: 20mph
    Power: 18volt NiCads
    Drive: 2 x 9v drill motors
    Controller: Secret!
    Weapon: spinning disk (lesson learnt from Dinky)
    Armour: Duarlium/Titanium/Gaffer composite (Tafffium)
    Status: Being buildeded now Dinkys dead.
    oh, hes got 12kg friends too, but youll have to wait for them
      Robot - Over Bite
      Weight - 12Kg
      Speed - Unknown
      Power - Havent decided yet
      Drive - 2 x 12V Drill Motors
      Controler - 2 x 30A Electronise
      Weapon - Grabbing/Crushing Jaw
      Armour - Havent decided
      Status - In the build.
        This database is looking good, anyway, Jas I know that you are looking for a linear actuator but I might aswell say this here aswell (I have put this message in in the featherweights.org forum aswell)
        anyway...
        email me for more info but heres the main specs on my actuator:
        Weight: 2kg (ish)
        Speed: 5mm per second @ 24v can be run at 12v or 36v though
        Force: 400kg push/pull Average, can get to 800kg...
        All this for only 25 pounds (this includes p&p!)
        Cheers, Ewan
          Swear your in competition with Technobots with all your batteries, motors, videos, toys, anything else robot related for sale.
          Stu
            I buy, I sell most of the time I make a profit...
              Robot -....... DTK
              Speed - .......10MPH APROX
              Power - .......19.2 VOLT NIMH
              Drive - .......2X BOSH 35W MOTORS
              Controller -.. 2X H5,S
              Weapon - ......10/16+ BAR PNEUMATIC FLIPER
              Armour - ......CARBON FIBER / KEVLAR
              Frequency - ..40.985
              Status - ......RE WORKING WEPON SYSTEM
                Robot....... RIP
                Speed - .......12MPH
                Power - .......14.4 VOLT NICADS
                Drive - .......2X DRILL MOTORS
                Weapon - ......10 BAR FLIPPER
                Armour - ......ALL TITANIUM
                Frequency - ..40.785
                Status - ......BENT, AND TIRED AFTER MR SYCO BULLIED IT BUT STILL WORKING WELL
                • #23
                  Robot: CBF
                  Power: 2 x 12V SLAs
                  Drive: 2 x 24V Gold Motors
                  Armour: 5mm Polycarbonate and 2mm Titanium
                  Status: Transmission Rebuild
                  • #24
                    Robot - Rebel
                    Speed - N/A
                    Power - x1 14.4v nicads
                    Drive - x2 24v golds
                    Controller - x2 15A Electronize Controllers
                    Weapon - CO2 powered Flipper
                    Armour - Polycarb and Ali
                    Frequency - 40.685MHz
                    • #25
                      Robot....... G2 (or is it Cheese 2?)
                      Speed - .......7mph
                      Power - .......22v nicads
                      Drive - .......Wiper motors
                      Weapon - ......140psi co2 flipper
                      Armour - ......4mm ali and 6mm polly
                      Status - ......Just ready to fight after RW
                      • #26
                        Definatly Cheese 2
                        Cheese boy
                        • #27
                          Robot....... microCHIP
                          Speed - .......18mph
                          Power - .......24v 1.8Ah NICADS
                          Drive - .......18v Goldmotors 5:1 gearbox
                          Weapon - ......LINAK crusher/lifter
                          Armour - ......2mm Ti on 4mm Polycarb
                          Status - ......Working OK, under test.
                          and
                          Robot....... BlacknBlue
                          Speed - .......5mph
                          Power - .......24v 3.3Ah NiMH
                          Weapon - ......45cm dia vertical spinning blade
                          Armour - ......3mm Ti and 6mm Polycarb
                          Status - ......semi-retired, on the mantlepiece
                          • #28
                            Robot - Bitchslap
                            Speed - Unknown
                            Power - x2 12v 3Ah NiCads
                            Drive - x2 24v Drill Motors
                            Controller -30A Electronize Controllers
                            Weapon - 44cm ali plate
                            Armour - 2mm ali/2mm poly
                            status - give me a event and Ill show you a bot.
                            Robot - Thuggernought
                            Speed - slow controlled crawl
                            Power - x2 12v 2Ah NiCads
                            Drive - x2 24v Gold Motors
                            Controller -relays
                            Weapon - poor control
                            Armour - 2mm ali/2mmpoly/3mm steel
                            Status - beginning major rebuild
                            • #29
                              stu,when are you going to update the featherweights.org database?
                              Whirlwind 3Volution is no more,
                              make way for its successor...........
                              Whirlwind 3Volution MkII
                              Robot - Whirlwind 3Volution MkII
                              Speed - approx 6-10 mph
                              Power - 7.2V 2000MaH nicads
                              Drive - 2x 6v r/c car motors(overvolted)
                              Controller - custom made
                              Weapons - 4x case hardened steel ramming spikes,1 titanium spinning disc blade,removable front scoop/plough,removable anti crusher weapons cage,removable Windcutter weapon system(can be combined with the scoop or the blade or the spikes to give better weapons
                              Armour - Polycarb and kevlar
                              Frequency - 40.680 Mhz
                              (starts to laugh evilly to himself over its potential):wink:
                              • #30
                                well amybe if you let us know about ur changes we can do something about it. And maybe somre updated pictures about it also. And how do we know that your robot is no more etc? In all hoensty, ive never seen it any even apart from RW in Extreme Series 2, so how are we supposed to know mate.
                                Regards,
                                Stu
