Featherweight Database
  • Featherweight Database
    DragonStrike no not on acid just a EV warrior with a Hardox 650 disc at 1 to 1
      Hey tony, do you have any videos of Dragonmaster on full batteries ? Ive seen it with low batteries and it looked feeble so I was wondering what happens on charger batteries
        Hi David
        At the moment no vid. I have rebuilt the axe mech it is alot faster now also shortened the axe shaft. It was not feeble before just a bit slow it was going through the floor in the hut well 2inch into the floor. Will find out This Saturday what it is like now its first comp.
          Cant wait to see it
          BTW, I was having a discussion with Matt (Mayhem) and we thought a big FW axe melee at an event would be a good idea, consisting of:
          Hells Angel
          Mayhem
          Little Hitter
          Basher
          Dragonmaster
          Pure Evil
          Sound like a good idea to you ?
            Looks like 2007 is gonna be the year of the axe rather than the year of the drum
            Nice to see their numbers on the up again - regardless of what damage they cause, they do make for good viewing
              and to play house robot in the hammer melee, thor no wait we need somethign that works Terrorhurtz it is then lol sorry dude loves u really
                Revision:
                Hannibalito Version 1.3
                2 x Graupner speed 900 drive @ 12V
                2 RC-Smart Speedcontrollers (aka the blue speedos)
                32 mm bore Full pressure flipper
                10 mm HDPE side and top armour
                Spektrum DX6 TX and BR6000 RX 2.4GHz
                Robbe RC switch with Bugs voltage Booster to fire Burkert.
                http://www.computerclub.nl/images/Hannibalito1_punt_3_1.jpghttp://www.computerclub.nl/images/Ha...1_punt_3_1.jpg
                http://www.computerclub.nl/images/hannibalito1_punt_3_2.jpghttp://www.computerclub.nl/images/ha...1_punt_3_2.jpg
                  Looks really good! Snap off a little video if you can and get a chance. I would like to see the drive and flip power of the thing.
                    New addition:
                    Hannibalito 2
                    2x Viper XXL (speed 900 equivalent) @ 12V
                    100 mm Blickle POEV wheels
                    65 mm bore Full pressure flipper
                    5 mm HDPE side and top armour
                    Bugs RC switch with Bugs voltage Booster to fire Alpha valve.
                    http://www.computerclub.nl/upload/images/100_0059.JPGhttp://www.computerclub.nl/upload/images/100_0059.JPG
                    Still needs some bungees, but apart from that its ready for testing.
                      Little Spinner 2.5 (pic on profile)
                      Mag S28-150 powered bar spinner
                      Drive 2x 18v drill motors 80mm wheels
                      Batterys 3x25.2v packs in parallel(GP 1100 2/3af)
                      Armour: front 2mm ti 3mm poly 1.5 ti sandwich
                      ends + back machined from 20mm thick ti
                      min thickness 5 mm
                      other sides 1mm ti 3mm poly 1.5mm ti
                      sandwich
                      Top 3mm poly.
                      Bottom 1.5mm ti and 3mm poly
                      Weapon 537mm long bar 60mm wide 20mm thick 1.8kg
                      Measured speed 2400 rpm @25.2v
                      Spin up time 2sec
                      controller scorpion XL (when i get it)
                      weight 11.6kg at the moment, just needs wires, speed controller(35g) and 2 more armor panels on top next to the wheels.
                        Looking good Graeme. I need more armour. Well I need to get Dragon 2 running again.
                          Got a driveable base panel done for Drumroll (quick vid http://s31.photobucket.com/albums/c3...roll.flv>here)
                            That is going to be one fast robot. Good luck with the rest of the build.
                              Thanks Ed
                              Dont know if it will seem quite as nippy when its at its full 12kg but hopefully itll still be enough to avoid trouble if necessary!
                              Ordered the tube I plan on using for the drum today too, which leaves just the endcaps and teeth as parts still to be accounted for - its coming together steadily
                                what a lovely kitchen
