Featherweight Database
  • Featherweight Database
    Hannibalito I in rebuild and his youngest brother
    Hannibalito II in build.
    http://robotwars.demon.nl/maddox/rebuild/http://robotwars.demon.nl/maddox/rebuild/
      Nearly there just got the electronics to fit. New pic on profile
        Nice one Tony! It better have a decent paint job like all your other robots!
        Mr Stu
          Looks like the Dragonstrike tongue bar has found its way on there already
            Latest picture of hornet 2 is on my profile. After looking at it in the flesh when cutting the aluminium panels at the weekend i decided to add an extra 10cm each side so it is now 75cm wide. Armour is 4mm ali and weapon supports are 10mm. Will either put 2mm steel or 10mm polycarb over the front depending on weight.
            Still got a lot to do but hoping to have it done by the end of the easter hols.
              DBA DBA DBA
                Nah thats Katjuscha.
                  dba?
                    DBA: Antweight World Series 18 winner, 3rd place AWS 19, always been a highly destructive force in Antweights (I ought to know, mines been on the receiving end !)
                      My ant, Katjusha (pic on profile) is based on DBA, and the new DBA is based on Katjuscha.
                        Nice one Gary, your feather is the same width or more than most heavies - looks like its gonna be a beast
                        If I can fit my proposed crushing claw into your old Hornet chassis, well need to get a lil match-up going after Easter (provided I get it finished over Easter). Dont need to worry about safe arenas or anything, my room exceeds the safety baseline for running spinners (cos it has solid concrete walls and a concrete roof - cant get more protected than that)
                        (Only problem being the drivers pods are integrated into the room without any separation - Ill get disclaimers drawn up )
                        Damn, too many smilies in this post for this early in the morning (oops, just added another)
                          Am I the only one that thinks the teeth on Hornet 2s disc are way too small?
                            hmmm
                            (Message edited by killercarrot on February 27, 2007)
                              Ill be honest, that thought had breifly crossed my mind too.
                                As long as they are long enough to clip another robot then I am happy. Whilst it may be a spinner I would rather just flip other bots with it to give the crowd something that looks good without doing much damage to an opponent.
                                I did a few calcs as well and with the speed that it will be going at, I wont get much of a cutter bite when I hit an opponent so making them large is pointless.
                                If it turns out to be a problem I can always see about getting another disc
