Featherweight Database
23Amps seems ok to me, I dont think that there is a problem as its only 207 Watts and they are rated for 750W Continuous, it depends on how effeicent the motor is running as this will determine the heat generated, and that can be checked holding your finger on it, if you burn it then its too hot
  I just checked a size 17 stepper motor this morning with only 2.4A at 5V and the case temperature of the motor was over 90C.
