Featherweight Database
  • Featherweight Database
    Tiamat
    Full Pressure Flipper 35 bore 80 stroke ram.
    18v drill motors run at 24v.
    4mm polypro armour not fitted yet.
    Pic on profile.
    Regards
    Tony.
      ooooo that looks good, reminds me of pressure
        Cobra (rev 4 i think)
        Speed: 12Kph
        Power: 2x 2.3ah SLAs in parallel
        Drive: 2x 9.6v Drill Motors at 12v with custom polyurethane wheels
        Controller: IBC
        Weapon: twin armed thwack hammer with 6mm steel scoop on the end (500g)
        Armour: 6mm steel and 10mm polycarbonate on the top and bottom.
        Frequency: 29.885MHz with a silvertone (http://www.silvertone.com.auwww.silvertone.com.au) military reciever
        Status: ready to roll. currently the state champion.
        heres some piccies:
        http://www.robowars.org/forum/album_personal.php?user_id=14http://www.robowars.org/forum/album_...php?user_id=14
          Loisteputki
          simple rammer with really thick armor and reliable drivetrain. (made from parts of LW robot [pic on profile] in one week, going also to patricipate as a LW with another FW)
          weight: 11.8kg
          battery: 12v/4Ah yuasa SLA
          drive: 2x900rpm/18v drills with custom alu gearboxes to 110mm wheels
          controller: servos&micro switches :sad:
          weapon: one steel spike
          armor: 4mm thick stainless (yup, in FW :P) and baseplate is 4mm 6061 aluminium
            Dont worry, youre not the only one with servo operated micro-switches for control. Im in that league as well, lol
            Jamie
              Ive just got my new site up, should be fully uploaded soon with new pics and updates.
              http://www.micro-maul.co.ukhttp://www.micro-maul.co.uk
                Good looking site Ewan, nice and slick.
                Jamie
                  -2>http://www.micro-maul.co.uk>
                    Flipper
                    Speed: 10mph
                    Drive Motors: 2x 9.6v Drill motors.
                    Wheels: 95mm Diameter 30mm wide Red Wheels from Australia.
                    Speed Control: 2x 30amp relay modified Speed Controlers, Gyro Stabalised.
                    Drive Battery: 14.4v 3000mah Ni-mh soldered pack.
                    Weapon: Low Pressure Pneumatic Flipper.
                    Weapon Power: Dual Ported 50mm bore 110mm stroke Maddox Modified Pneumatic Ram.
                    Weapon Control: 2x 1/4bsp Festo Pneumatic Valves.
                    Weapon Power: 600g Co2 via regulatos to 750ml buffer tank.
                    Weapon Arm: Custom Built from Aluminium and Polycarbonate by Roaming Robots.
                    Weapon Foot: Custom made from Titanium by Roaming Robots
                    Valve Control: Servo with microswitch powers the valve with its own 24v 0.3amp supply.
                    Armour: 10mm polycarb, 6mm polycarb and 12mm plywood.
                    Frequency: 40.685 Dual Conversion.
                    Status: Built, awaits Gas Bottle and regulator, See render on profile.
                      Looks quite like the robot Roaming robots built for a kid, although it appears this one doesnt have a buffer:
                      http://www.roamingrobots.co.uk/services_robots_ouroboros.htmhttp://www.roamingrobots.co.uk/servi..._ouroboros.htm
                        Ewan Its basically the same robot as I had with me at Bristol, Newcastle, Stoke on Trent and GGHW last year. Just re-arranged inside. It is in no way connected with the roaming robots bot.
                          name - Hornet
                          weight - currently 11kg
                          speed - unsure
                          drive motors - 12v wiper motors running on 24v
                          weapon - 2kg hardox disc spinning at a few thousand rpm
                          batteries - 2 x 12v yuasa 2.1Ah
                          armour - 4mm hardox 400 front and sides and 6mm polycarb top
                          strengths - It is built and driven by me
                          weaknesses - It is built and driven by me
                            Name - Vertigo
                            Weight - Hopefully 12kg
                            Speed - Havent a clue but calculations show around 8mph
                            Drive - 2 Unmodified (but obviously stripped-down) 9.6v drill motors
                            Power - 3300mah ni-mh GP cell pack, 18v
                            Speedo - IBC, soon to be replaced my my own speedo
                            Armour - Mixture of 10mm polycarb and 3mm steel plate
                            Weapon - Big Vertical disc (290mm) made from two layers of Hardox together. 12v Gold with 1.8:1 timing belt reduction, should peak 4500rpm-ish
                            Status - Being finished ready for Magna event
                              Ewan, Ive tried big (300mm) vertical disks with 12v gold motors on BlacknBlue. Sadly they just arent up to the job, even overvolting a bit they take an age to rev up to any sort of speed. Use a cobalt motor like astroflight.
                                Also a timing belt probably isnt the best to use, as it will probably strip. Use either a V belt or a round belt. If your worried about it slipping when spinning up then maybe look at chain.
