Featherweight Database
  • Featherweight Database
    My uniqueness as a uk drum weapon is gone forever *sniff* *sniff* lol.
    Chris - http://www.featherweights.org/forum
      Pics of new G3:
      http://www.teammad.co.uk/G3down.JPGhttp://www.teammad.co.uk/G3down.JPG
      http://www.teammad.co.uk/G3up.JPGhttp://www.teammad.co.uk/G3up.JPG
        Wow, thats a big change... what things are different (e.g what armour have you now got?)
          Amour, 6mm Polly Pro and 8mm ali back. The chassis is made from 4mm Ali. Everything inside is the same, apart from some 10mm pipe. The flipper is alot more quicker aswel.
            I dont think you will have to worry too much Chris. Theres no ev warriors or solenoids on this drum( remember Major Tom = garden shed produced lol).
            Only decided to make a drum weapon as i found i perfect peice of 100mm s/s pipe to use! May or may not work. will find out soon enough.
              LOL! Glen what do you think Conundrum Mk1 is, its also garden shed produced bot and so is the :new: Mk2.
              Oh btw see profile pic for abit of fun ive had with Zeros chassis, if only i knew how to weld when building Conundrum Mk1 lol just playing. Hope its more of a success then Conundrum was :wink:, what motor you using for the drum?
                New chassis looking very nice Chris!
                Dave- Team Turbine
                  LOL!
                  Humm.. now is Dave being funny or is he really that clueless?
                    Im saying nothing.
                    Mr Stu
                      Now thats funny Chris!
                      Certainly woke me up this morning!
                      Am planning to use a 9.6v drill motor at 12v geared down to run at approx 4000rpm. Ill see how that goes before i start buying better motors.
                      btw - the gap at the back is for a static wedge.
                          BonX 2
                          Weight: 12kg
                          Weapon: 50*65 mm FP CO2 flipper
                          Drive: 2 100 mm Bickles with SPEED 600
                          Battery: 3000 mAh 14,4v NiMh
                          Speedcontroller: Electronizes
                          etc.
                            FlowRate
                            Speed: 14Kph
                            Power: 1x 14v 3000mAh soldered NiMH Pack (thanks for the advise ed I can really see the difference)
                            Drive: 2x 9.6v Drill Motors
                            Controller: 2 x 30amp Electronize (wish i could afford the ibc)
                            Weapon: High flow rate low pressure 10bar Pneumatic Flipper
                            Armour: 6&10mm Polycarbonate
                            Frequency: 40.685MHz
                            Status: Dismantled due for a rebuild for next summer
                              WTF are you doing Ian?
                              Mr Stu
                                Mistake Big Mistake.
                                I coppied the info from Flowrates bio on the first page and forgot to change the name to flipper .
                                Really sorry stu. Ed can you clean this up please by replacing Flowrate with Flipper please. Thanks.
                                Regards
                                Ian
