Featherweight Database
  • #31
    Robot - screwed
    Speed - 13mph
    Power - 12v 7Ah SLA
    Drive - 2x9.6v drills @ 12v with 150mm wheels
    Controller - custom made microswitch boards
    Weapon - spinner killer plough and wedge
    Armour - 6mm lexan, 2&3mm aluminium and 4mm steel
    Status - retired after wooden motor mounts broke
    Robot - So Screwed
    Speed - 13mph
    Power - 12v 7Ah SLA
    Controller - oatley electronics 60amp PWM ESCs
    Weapon - thwack spike 470mm from center at 50km/h
    Frame - 20x20x1.2 steel box section MIG welded
    Armour - 6mm lexan and 3mm aluminium
    Status - being built.
    • #32
      Robot....... STRIP
      Speed - .......10MPH
      Power - .......12V 7AMP SLA
      Drive - .......2X DRILL MOTORS
      Weapon - ......NASTY 500MM SPINNING BLADE
      Armour - ......STEEL
      Frequency - ..40.785
      Status - ......BRAND NEW PROTOTYPE, TESTED AND OVER WEIGHT AT THE MOMENT. IF IT WORKS WELL THEN THERE WILL BE A NEW TITANIUM VERSION FOR 2004
      • #33
        Robot - Icklerus
        Speed - 12MPH
        Power - 2 x 12v 3ah Nicads
        Drive - Drill Motors
        Weapon - 80mm bore pneumatic flipper
        Armour - ti, polycarb, aluminium
        Controller - electronize
        Status - Being Built
        • #34
          Robot....... STRIP (aka Tantrum 2 you idea robbin git!! kidn )
          Power - .......12V NiCad
          Armour - ......Titanium
          Frequency - ..40.765
          Robot - Trinity
          Speed - top secret
          Power - top secret
          Drive - top secret
          Weapon - top secret
          Armour - Duralium/titanium
          Controller - top secret
          Status - awaiting gearboxes...... be afraid!
          Robot - Whiplash
          Speed - 8mph
          Power - 14.4v Nicd
          Weapon - 80mm bore pfull pressure pneumatic flipper
          Armour - titanium/polycarb
          Status - prototype works, need to get reliable bits made now (ie broke it!)
          Robot - Tantrum
          Speed - 30mph in theory
          Power - 28.8v nicad
          Drive - gold motors
          Weapon - silly 500mm spinner
          Armour - eh.... dammit, must write things down! none!
          Status - Built, fought, banned, modified, close to retirement.
          um..... thats it for now I think
          oh, hang on
          Robot - carnage (formally known as wrawhead)
          Speed - 10mph
          Power - top secret
          Drive - top secret
          Weapon - spinning dome
          Armour - ti, aluminium
          Status - Being held ransom.
          • #35
            James,
            Reading through that lot, Im struck by one thought....You have far, far too much time on your hands!!
            • #36
              what ya on about.... its nothing like tantrum....
              the disc is old neoterics, which was the 24kg walker in last years extreme, and when you see it.... you will notice the difference.
              jonno
              • #37
                I know, I thought it was that one. I saw it at Ironbridge last year.
                Just messing wiv ya because on paper its quite close.
                too much time on my hands.... oh if only.
                Too many projects not enough time.
                Started a bloody 24kg walker now, and the others are still not all finished. One day Ill learn. At least Dinky is dead so I cant use that as an excuse not to finish another....
                Gear boxes for Trinity arrived today, any heavyweights want a fight?
                • #38
                  Hey, What weapon are you using for your featherweight walker?
                  Cheers, Ewan
                  • #39
                    James - Trinity a feather weight right?
                    Dont mind having a little play with Pussycat against it
                    Mr Stu
                    • #40
                      ok stu. do you want to run your disc?
                      Ewan, the walker has a vertical disk head, and an articulated crushing body.
                      • #41
                        Oh thought yours was a flipper.
                        No no no - not putting Pussycat in with soemthing that may scratch it LOL.
                        Mr Stu
                        • #42
                          got a pic of rebel as its standed after malvern
                          loads of things arnt in the pic but its a peek at whats there
                          cheers for temp host stu
                          http://www.featherweights.org/featherweights/rebel_feather.jpghttp://www.featherweights.org/feathe...el_feather.jpg
                          • #43
                            robot: gnar kill
                            speed: 13mph
                            power: 12v 3Ah NIMH
                            drive: 9.6v drills at 12v on 150mm 20mm thick lexan wheels.
                            controller: IBC
                            Weapon: 400mm spinning hammer. 5000rpm brobo saw coming soon.
                            armour: 6mm lexan.
                            status: was called screwed, was rebuilt using its parts and is a further refinement.
                            • #44
                              Robot - Flipper
                              Speed - 9mph
                              Power - For Drive: 9.6volt 3000mah NiMH or 14.4v 1900mah Ni-cds
                              For Compresser: 9.6v 1000mah Ni-cd or 12v 1000mah Ni-cd
                              For Solenoid: 24v 2300mah Slas (far too many batts on board)
                              Drive - 9.6v Drills Driving 150mm Diameter wheels
                              Weapon - Compressor driven flipper
                              Armour - Hardboard and Plywood atm but moving to lexan.
                              Other - Not intenede for combat in current state only for demo.
                              • #45
                                Robot - Turbine 3
                                speed - about 4mph
                                power - 2.8 slas (24v)
                                drive - wiper motors
                                controller - 15amp electronise cpus
                                wepon - 10bar flipper
                                armour - 3mm,4mm, 6mm ali + 1mm polycarb
                                Status - im tryin to make the darn thing reliable! but its still working
                                regards
                                Dave moulds
                                Team Turbine
