Feather weight motor suggestions......
just a few of suggestions based on the chassis as it was when you got it....
1- golds are too big, youd need to increase the height. means modifying the chassis shape.
2- 900s, bigger than drill motors and you still need gearboxes, so youll need to make or buy a gearbox, and they stll wont fit inside the chassis without wheels outside.
3 - just use 4 cheap drill motors with external wheels, and add 10mm polycarb sides to enclose them. You will need to cut these polycarb bits, and some bolt on brackets, but thats easy enough. I recommend this option.
