Can somebody help me ?
Yoeri, There are lots of small speed controllers out there. I prefer Electronize but M.Sonik controllers also work. Both can be plugged directly into a receiver. Technobots carries the Electronize controllers (and some others). For about 40 pounds you can have two channels of control, one for each motor, which will do the same job as the Rex controller. Good luck with your build.
