Failsafe problems
    Failsafe problems
    Ive checked an online manual....nothing in it...hence asking on here, lol.
      Failsafe problems
      OK, now one side failsafes but the other side twitches...wonder if its just picking up some rough static or something...Ill try it outside.
        Failsafe problems
        You might have tried it already, but it could be just simple things such as:
        Loose ariel wire
        Loose connectors
        Charged the Transmitter/Receiver battery
        Connected the right channels from the reciever
        Matching crystals?
        etc. etc.
          Failsafe problems
          The sabretooth on Ironside was on 40mhz originally and had the same problems with twitching - solved the problem by fitting a br6000 - sorry.
          One other thing to bear in mind, 95% of your opponents will be on Spektrums and will not have radio suppression fitted, so your machine will be severely affected in combat.
            Failsafe problems
            Dave, have you got the auto calibrate on your sabretooth switched on?? If so turn it off, I have had similar problems with the 5 and 10Amp versions and this seemed to fix it.
            Will
              Failsafe problems
              Thanks for all the help...the robot went up in smoke today, lol, so thats that problem solved kind of.
              Should have it fixed up for Barnsley though...might just have to bite the bullet and get a Spektrum.
