Team Kaizen - Kaizen
  • #61
    Just seent he video of F7 at manchester, cor they legged it out with that bot in the end didnt they! need to have a wheeled trolley next to stage to wheel them out lol *takes H&S hat off*
    • #62
      hahahaha, it is "only" 44Kg I think - I don't recall seeing it being lifted on and off the pen though. I definitely saw it on a wheeled platform of some description at Guildford, will need to remember to get one of those.
      • #63
        So here is the bad news - Kaizen is very likely not going to Grantham. The wheel issues and the lack of time owing to real world stuff means that I can't dedicate enough time to getting it battle ready. I am dedicated to getting the whole thing finished in time for EXR Chatham though.
        The good news is that the wheel hubs have been adapted and fitted, just needs threadlocking in all the right places and then I can finally test it. Front polycarbonate panels are mounted and all of the steel roofing brackets are mounted. Just need to not sleep now for the next 10 weeks to get it done now :P
        • #64
          That's a pity -I was looking forward to seeing or even fighting
          a new heavyweight at events.
          • #65
            I am fairly sure there is another new HW at Grantham as well. If I can get Kaizen moving by tomorrow evening, then maybe, just maybe... it definitely won't have a weapon though.
            • #66
              Well I certainly look forward to seeing Kaizen fighting, but don't feel like rushing to get the bot ready ASAP if it'll half kill you to do it and result in a fragile bot. There are some pretty powerful MW's already in the UK; it would be a shame for the bot to be destroyed before it was truly finished! It's up to you at the end of the day, but if there is going to be a middleweight tournament later in the year, it may be worth focusing on being as ready as can be for the premier event over all other shows.
              • #67
                This is the point I keep on debating with myself. Technically, I can get it mobile before Grantham and given it is Team Kaizen's anniversary, I want to celebrate it in style. I do have a backup just in case but this has been a long time coming and whilst it would definitely not have an offensive capacity beyond pushing power, it is solid at least.
                • #68
                  So Kaizen never made it to Grantham, it just wasn't ready in time. The wheels continue to be a problem, I got some M12 plates to mount the wheels to, drilled out the bolt holes to M8 and they are fine but, perhaps a little naively, the threadlock on the motorshaft just isn't enough, it tore a wheel off.
                  I have a last roll of the dice, I have some different M12 hubs, I'll see about drilling a bolt through the threaded sections of the hubs and the motor shaft to try and lock these in place but I don't think I have the facilities to do that with, certainly not the upper body strength to do so. If I can't get them done, I really don't know what to do next.
                  • #69
                    Hi Michael, can you wait until you get to Leeds (Robodojo event - if you are going that is?), or perhaps post a photo or two of the problem. I maybe able to help.. mechanical engineering is my field.
                    Regards
                    • #70
                      Since my last post, I've found that I can drill the flange relatively easily but fouled up on the motor shaft.
                      Initially, my idea was to use the flange fitting as a wheel hub and have a M5 locking pin running through the shaft to secure it. However, in the second photo, you can see that the hole is very close to the end.
                      After speaking with Alex from the Cracker 'n' Smash team on this one, whilst that hole won't break as I feared, the issue is that my flange is on the wrong way around and the holes I've drilled to put the pin through are too far up the shaft when fitted the other way around so I don't see the motor shaft through the hole in the flange. a couple of recommendations came in the form of taperlock bushes or use a shaft support for linear guide rails (https://www.gearsandsprockets.co.uk/...ails-12mm.html).
                      • #71
                        How about cutting the length of the hub shaft down so the hole matches the motor shaft location point?
                        • #72
                          If the flange was going to sit the way it was in the previous post, I'd possibly agree but the flange is the wrong way around, it needs to be in this orientation, which the holes in the flange already no longer reach the shaft.
                          • #73
                            Ok, what about drilling another hole 90 degree to original but in the correct position for the motor shaft? In other words further towards the flange? If you don't have the facility to do this, any machine shop will pop a hole through for you, just need size and location. You may know someone who has a pedestal drill, in which they would be able to do this for you again as long as the location and size is known.
                            • #74
                              Yeah, that was what I suspected I may have to do. I have a pillar drill attachment but not a clamp that fits so I'll see if I can find someone with a facility to this. Thanks
                              • #75
                                How are you anticipating to fasten the hub to the motor shaft. Looking at the pics the hole in the motor shaft is blind. Are you going to take it through the shaft or going to thread the hub shaft?
