Well, the 2.2 refit has been a while coming. It has been 116 days since the 12th of December 2017 when the refit technically started and there has been a few setbacks (largely of my own making) but finally, The Honey Badger 2.2 is completed!
The lifting arm is now interchangeable with an axe attachment which although the motor is not ideal for such an application, works as well as I can expect and if I do end up doing a 2.3, that will be the main change. The white safety tether looks slack in the picture but it tenses up as it goes down and should do the job here.
You'll note the large slab of Aluminium for better impact protection this time around and the much thicker and larger side wings being made out of 4mm steel so hopefully being flipped up and over will be a thing of the past.
Internally, apart from the added weaponry wiring, not much has changed apart from the switch over to a OrangeRX system which I am readily getting used to but I do still need some more driving time with it. The armour is still 10mm HDPE with 3x 40mm Oak chassis crossmembers along with the 5 bar tread plate at the front and sides.
There are still tidying up jobs to do, notably the front plate bends over too far grounding out one side of the robot on the floor but that is a 10 minute job to cut off the excess and tidy up so not too concerned yet. I'll see if I can get some videos of it running around tomorrow.
