On point number 2, the easiest way would just be to use a servo to turn on a couple of microswitches, one for each direction. It allows you to control forward and back from one radio channel and the stock actuator motor will have a low enough current draw to not require any additional relays etc. Here's a setup in its simplest form; I usually tend to just hot glue the switches onto the sides of the servo and wrap a cable tie around them, but you may prefer a more robust/maintainable/aesthetically pleasing alternative
