I've had people ask for some of the sketchup models I've made, and I'm going to post download links to them here, but I had the idea that maybe this thread could be just a general sharing thread for 3D models (of any kind) that people make for their robots, to allow those who prefer to do CAD to better plan their robots as a whole. So if anyone else wants to submit anything, just post a download link to your models and say what they are, and what format.
Please bear in mind that my models aren't perfect. They're pretty close to the real thing since I measured the part and then made the model. But don't use them as a basis for any really precise machining or whatever, since the dimensions are only really correct to half a millimetre or so, and some little parts are missing (like the screw holes on the end of the drill gearbox).
Antweight Stuff:
The small brushed gearmotor that a lot of people use for antweights (the gears themselves are not modelled):
https://www.dropbox.com/s/qv2wrlu4u3...arbox.skp?dl=0
The Dys 2300kv outrunner brushless motor that I and some others use for antweight spinners:
https://www.dropbox.com/s/o1js1fr3at...Motor.skp?dl=0
The 3D-printed wheel that Rory Mangles packages with his NanoTwo V2 Antweight ESCs:
https://www.dropbox.com/s/hvzxcx3jk3...Wheel.skp?dl=0
The 3D-printed motor mount that comes with the NanoTwo V2 ESC:
https://www.dropbox.com/s/hzbtj9v8iu...Mount.skp?dl=0
A measurement box for you to put your finished antweight design inside to see if it fits. A 101.6mm cube with 'tinted' windows so you can see if any parts stick out:
https://www.dropbox.com/s/27wmqllqns...20Box.skp?dl=0
Beetleweight Stuff:
1000RPM brushed gearmotor commonly used in beetles, note mass is not correct as the space inside the stator and gearbox are not modelled, just the external features:
http://a360.co/2t7UzG3
Featherweight Stuff:
Drill motor with gearbox:
https://www.dropbox.com/s/jlvzz3orw2...arbox.skp?dl=0
A Turnigy HeliDrive SK3 600kv brushless outrunner - should be applicable to similar models too:
https://www.dropbox.com/s/h38bukmvi8...Motor.skp?dl=0
Just a simple cuboid that represents the Spektrum AR610 receiver that I have (and many other types), can be used as a size guide:
https://www.dropbox.com/s/7yx9c73m4k...de%29.skp?dl=0
Heavyweight Stuff:
An Etek ME1004 I made in Fusion 360, from the given schematic drawings:
http://a360.co/2p0Xtdg
Antweight Stuff:
Beetleweight Stuff:
Heavyweight Stuff:
