This is an area about which I'd like to have the opinions  of EOs or tech checkers to see if I comply with the rules.
I have not included a dump/vent valve in the system. The reason behind this being that when solenoid valve has no power supply the flipper will fire, and I'm not keen on removing the power manualy from the robot (ie removing the link) before the gas system is vented.
So after a fight is over, I will fire the weapon - now the system is totally empty of gas and the flipper is open. I can now remove the link, with the link out, there is no way the weapon will fire again. Last step I will close the on/off valve.
Don't know if it's clearly explained, I will do a step by step guide with pictures of what is happening and where.
