Love the colours though
[FW] Wedge Spinner in time for Robo Challenge champs!
Hopefully not! I should have proof of that today hopefully. Ninjaflex printed at 100% infill is pretty hard to stretch at this thickness, and even when not completely tight on the pulley it gripped very well, so I'm hoping it will stay that way. Time will tell!
This current belt is just flat, if it proves to be up for the job I will experiment with printing some with HTD5 tooth profiles, although If the belt does stretch, the teeth could just do more bad than good...
The bot drives!! Its an absolute power house with those rangle gearboxes/motors. Had good fun pushing the dog bed around with it (minus the dog). We didn't manage to get our ESC's finished in time... they run the bot... but theres so many little things to fix/add to them that its not worth the risk this soon to the champs. Instead, Dave and I spent the day making removable links, flashing tz85's and general wiring/extras. Really happy with the outcome.
Also
THE WEAPON IS ALIVE
The ninjaflex span up the 2.2kg disc really nicely!
Probably a good call on the ESC front; My feather had a fairly untested ESC in it for the champs last year. It only lasted one fight, then had to be swapped out for some TZ85s anyway.
It's looking awesome. If your countersunk bolts don't arrive in time, I'd suggest removing the lower 6 of the 8 cap head bolts from just in front of the disk, else you'll never hit anything!
Very clever! I would go for the fibre tape if its like the fibre reinforced packing tape I have - absolutely not stretch in it. OTOH, duct tape is probably stickier. If you run a test, run the belt until it gets hot - my duct tape glue melts at low temps.
