Man, you should leave that thing unpainted. It looks gorgeous!
Metalskullrobotics build thread
 today made a first test drive. But there is a problem the shock absorber's where the gearbox is attached to are to soft.
 When the wheels need power the gearbox is pushed backwards and the belt slips. I have to make a ring that will hold the gearbox in place but still make it possible to flex.
 stef
 On the above picture the wiring is a big mess, i will do some nice cable management to prevent cables hitting the motors.
 today made two bushes that will hold the drive axle in place and made a test drive. It works perfect and the motors are still able to move a little.
 https://www.youtube.com/watch?v=IwJN0guaFHM
 stef
 Yesterday made a battery tray and wired everything. The robot seems to have a little overweight issue with almost 1 kilo. Today started on a big diet, make hole's in the big bolts and make the axes that hold the wheels lighter. The last bit of weight will be milled out of the two alu frame plates of with are right now 1 kg a piece.
 stef
 Almost there, right now only just 80 gram over weight. We want to replace the bottem plate for lexan instead of alu.
 http://gallery.svitterzon.nl/cache/a...2015.18.40.jpg
 stef
