Building The Big Bamboo
  • #31
    Looks like a parachute .
    How did those bars fair against opposition? Did they not fly off? And I didn't consider growing the stuff, I don't know how I'd manage to get that past the girlfriend to be honest.
    • #32
      The roll-over hoops are made of UHMW and have been really reliable; because they are quite springy, they also provide some shock protection when the bot lands upside down. The front one was cut in half by a vertical saw bot but that is the only real damage they have ever taken.
      You would probably need a greenhouse to grow bamboo in Birmingham but as some species grows at up to a metre per day, you could have a frame is about a week.
      • #33
        I'd need a greenhouse with central heating to grow it in Birmingham!
        I see your point though. I bought some bamboo and it was delivered last week, turns out the bamboo I bought is too thin to be used how I intended it. BUT, there are 50 canes at about 1.5/2m lengths and incredibly light. I tried to bend one and it was difficult to get any sort of bend in the cane.
        So I think I'm on the right track with the frame at least, I just need to order thicker bamboo. I ordered 14mm thinking it was in reference to the thickness of the cane wall. What I'll be going for next is 25/30/40mm thickness. However the thinner bamboo would probably be ideal in a triangle formation around the base of the frame. I'll give it a try at the weekend.
        • #34
          You can bend regular wood after steam treatment: https://en.wikipedia.org/wiki/Steam_bending that may or may not work on bamboo. Wood can also be bent with an ammonia solution - pretty sure your GF is going to veto that one!
          • #35
            Originally posted by overkill View Post
            Or you could bend some bamboo as shown below and automatically self-right with no power or coding:
            If you grow your own bamboo, it is possible to train it into shapes like this with a frame - if you are aiming for an environmentally friendly bot, its the only way to go!
            Only problem with that is other robots hook you don't they Nick
            • #36
              Not just robots, but inanimate objects too. None in particular, definitely not a small tyre used to activate the pit in the RC arena. Absolutely not.
              • #37
                I HATE that tyre! The 2016 version of Mr Mangle has a fix for that.
