Had this in the pipe line for a short while now- hoping for this to be next years uk champs entry depending how it progresses too
Been gathering parts gradually and almost have everything to have a go at building one sides drive unit.
I like the idea of building something different (and hopefully good :P) so it will be a tracked feather weight running off a pair of speed 900s thru a custom 2 stage gear box with an actual weapon and not a spinny one!
Since i started my new job back in november i stumbled across these timing belts with an outer rubber layer on.... which ive always thought 'god they'd make nice grippy tracks', so im giving it a go to see how they end up performing
These rubbered belts are used in the machines my work build and run almost 24/7 in most cases and never seem to snap/break but obviously do wear over time!
Few pics below of parts!.. the drive pullys arent the correct ones atm-just there to give an idea
