pp3d
  • pp3d
    New build thread for a potential new machine. I have no idea if I will have the time and cash to get it built but we will see (weddings are expensive!). PP3D is planned to be a heavyweight spinner using mainly parts that have been sitting around gathering dust occasionally dusted off when I've moved house. Stats and mock up picture below.
    - 31kg, 20mm thick hardox disc. 700mm from tip to tip. Same disc that I had made for swarm years ago and has never actually spun up. There were a number of design flaws in that machine that i'm hoping to learn from. Disc shaft will be very large diameter between two taper bearings to take vertical and horizontal loads. The disc will skim just above the ground, perhaps 10mm or so.
    - Powering the disc will be one of the two eteks I have. The other being a spare. These will be controlled by a solenoid relay. Nice big, beefy and simple. Probably look at using V-belts to connect the two. Give a bit of slippage in the system to buffer damage to the eteks from sharp stops. Plus they are dirt cheap
    - Currently looking at iskras for drive as I have a couple sitting around. Also have a couple of bosch 750s from SMIDSY kicking around but we will see if those get used or not. The iskras are nicer as they have a smaller body and are a whole kilo lighter but either solution will require a gearbox to be made. As ever timing and cost will need to be taken into account. Wheels are currently mocked as some old ones from storm 1 that I got a hold of a number of years ago. Don't know if I'll use them or not. Would prefer something pneumatic to help absorb some of the loading the machine would see.
    - Batteries will likely be whatever lipos I fancy using / can afford to run.
    - Drive will be controlled by a big vantec. One spare sitting there as well.
    - Armour, mixture of hardox and titanium.
    In terms of the appearance of the robot I want to try and make it look like a steampunk style machine so I may be experimenting with copper and bronze plating and including some wooden elements as well.
    edit - I guess the forum is setup to stop all caps in the titles
    Thanks for the banana in shot, I'd have been lost without it.
      Looks very promising.
        Quick update. Found the perfect material for the disc shaft. Large diameter billet of titanium. Picture below. No banana for scale I'm afraid. Weighs a heck of a lot but should be plenty strong to take the hits.
        Also found some nice looking pneumatic wheels that I think I'll use in place of the solid ali ones.
          If you find someone that will build you gearboxes will you let me know.
          Robot looks a bit scary!
            I'll just get to making them myself. Will require a bit of time on the mill (and a good bit of time learning) but nothing I can't turn my hand to with a bit of practice.
              Which pneumatic wheels have you found? That billet is a beast😀
                So made a bit of progress, thought it was time to update the build diary. Here's the finished robot and the first spin up.
                https://youtu.be/2aciMs5nYbA
                  Hmm, I see potential in this machine.
                    Are you mad standing so close to that spinning blade? You could hurt yourself.
                      sadly when i saw it in the flesh all i could think of was those poor exposed wheels. Looking forward to next weekend though cant wait to see what it did in the arena.
                      One thing last night shown was a good driver can make a massive difference. Hope you had plenty practice
                        When you have a weapon as powerful as PP3D, it really doesn't matter
                          Everyone looks at the wheels and forgets about the disc
                            That looks brutal mate, how high is the disc off the ground?
                              Just 20mm, really is a floor-hugger
