They look a little heavy Calum.
Disturbance
Having no time what so ever to get this done! But cncing new mounts for this beater next week intime for the insomnia gaming festival robochallenge event! No more 100% boring box
shud get my new wheels sorted intime for this too
The new mounts will allow the robot to run upside down on its rear 2 wheels without interfering with the weapon! Got a new much more powerful magnet on order too
So set up wise I'll have,
Full hardox shell for dealing with spinners.
Flappy shell- which gets under almost anything!
And the beater set up which will be for nice chunky robots who like to fly about!
Progress! Working nights is mint when the managers leave half way through the shift! Haha
Machined the battery frame to allow the battery to spin around so it clears the beater motor. Put the new beater pully on a lathe and drilled the center out also, tonight I'll be drilling and pining the pully to the beater so wish me luck!
Altered the front motors rear support to clear the beater and motor.
The speed 900 and bracket are from Ts3 which in its heyday was mint so sticking with that for ease. Next week's job is to get the beater mounts remade!
Ordered a shorter timing belt also.
Progress...
beater setups almost done. Few mechanical bits to sort out still mind.
Gone with a loose ground skimming flappy strip of hardox ground down to a point along the front edge in the hope flippers will ride up it and get their blades mangled!
Still needs a rewire yet too, due to time Im sticking with the beater mounts dave made all those years ago as they'll do the job for now
After almost 2 years it'll be nice having a spinner again!
Spent the last few hours rewiring! All done accept for the weapon speedo as I was getting fed up by this point!
Popped over to the coopers Saturday to use their miller and lathe so big thanks to them. Successfully pinned the beater to the pully. Feels nice and solid.
Need to make a little tensioner for the weapon belt, Mount the fuse into its new place then mill some weight out of the large outer drive bulkheads as it was 13.5 before rewiring and adding extra welds to the outer shell!
Took extra weight out of the drive bulkheads, opted for doing it on the out side edges purely cause I thought it'd look cool being seen haha.
Painted the new beater shell too, may repaint the other 2 shells to match if I get time.
Various pics below....
Cheers!
Finishing off final parts of the beater Setup today! Sorting out the tensioner for the belt. Tried it 1/4 speed with the belt flapping about and it seemed relatively happy so fingers crossed for full speed!
