"£50" Heavyweight
  • "£50" Heavyweight
    Ok, so I've done antweights and featherweights before, and I've never yet spent more than £50 on a robot (at least, before it's first fight). Now the question here is, can I do the same for a heavyweight? Having looked through my parts collection, I think I may well be able too..
    Wheels:
    I have a few go kart wheels (given to me years ago by a friend) and a load of wheelchair wheels (from an old school project) lying around; Ideally I'll use two of the small go kart wheels if possible.
    Batteries:
    Picked up 3 of these UPS SLA battery banks for free that were being thrown out by a local law firm. Each individual battery was originally 12v @ 5Ah, however they're down to about 1.5Ah now.. But since I have 30 of them I can just add a few more if need be! They still give out plenty of current which is the important part
    Drive Motors:
    This one's a little more tricky; I've got two pairs of 20 year old wheel chair motors (left) lying around... However they have very little power (less than 200W I think), which is hardly ideal. The other option is a set of lawn mower starter motors (right). Not particularly efficient, but have plenty of torque at quite a low speed, meaning single stage reduction should do (I've got plenty of small cogs and chain around). However, I only have one atm, but I know where I can hopefully pick up a few more for <£10.
    Armour and chassis:
    Just blown half my budget on two square metres of 10mm Polycarbonate from John, but also have plenty of resin bonded 20mm plywood if need be... Not exactly Hardox, but should keep the dirt out at least :P
    I have plenty of good solid steel lying around for the chassis; should be plenty enough for a heavy at least!
    ESC:
    Another tricky one. All my my robots have used homemade ESCs up to this point, however buying parts for ESCs can get expensive (my featherweight one was ~£20). A (hopefully) cheaper way to do it is to buy a pair of these and basically do a complete rebuild of them so they're usable. More details on that plan can be found here.
    Weapon:
    Haven't got any exact plans yet. Found a couple of 2 foot long hardox spikes on one of the old bits of farm equipment, and either a full hydraulics system, or a 6 foot x 2 inch screw thread that I could make a lifter from... Leaning more towards the screw thread atm as it's less messy..
    I've spent £25 on armour so far, about another £16 or so will be spent on ESCs, and the rest'll probably go on another drive motor... I'll be very impressed if I do actually keep it under £50, but definitely don't plan on going over £100 :L
    Time to get building!
    Good luck with the build
      Ok, bit of an update:
      I've put off starting the build until next easter/ summer, which gives me plenty of time to source cheap parts. My main sticking point atm is drive motors, with a second lawn mower starter motor not forthcoming (The guy I was gonna get them off didn't have any). I'm going to keep an eye out on eBay for any suitable cheap motors. Hopefully with a year to browse I'll find something half decent; I'm currently leaning towards some wheelchair motors to keep gearing simple.
      I'm also looking at scratch building the ESC again, as the cheap ESCs I was looking at before were missing proper gate drivers which makes them unusable for this even with hacks. Having done a bit more research and reverse engineering various ESCs such as the TZ85, I've been working on a design for a dual ESC capable of ~40A continuous @ 40V which is pretty simple and cheap on parts (~£20) and can easily be upgraded to more amps with different/more FETS, though if it's just wheelchair motors, 40A should be fine...
      As for weaponry, I'm still going for the forked lifter, however I'm thinking of using a cable/ rope winch with block and tackle pulleys along with tensioning springs to stop it all getting tangled... largely because it's cheap, light, and it'll look cool though the polycarb; I'm aiming for a bit of a steampunk or post apocalyptic look for this one (might get some riveted corrugated iron or something over the polycarb in places for that Fallout 3 look :P )
      I've decided to up the budget to £100 just so I can get some parts that'll work for more than one fight. As I say only thing I'm really missing is drive motors, but there's always plenty of small parts which add up quick. My aim is to make something that may be a bit useless, but is fun for the crowds and as solid as a rock
        The first prototype for the ESC is working nicely:
        (Yes, it's a terrible test rig, but it's what I had around)
        This is just a proof of concept i threw together last night to check that all the components I'm planning to use work together as planned, and that the MOSFETs are all switching efficiently. The drill motor is several times smaller than a HW drive, but it can control it without warming up at all which is what I was aiming for. Worked first time as well, which has never happened before when I've developed previous ESCs! :P
        The PCB layout for the full version is mostly done; It'll be able to drive two motors at 24V, and have 2x100A surface mount FETs in each 'corner' of each H bridge, though given the pins on the FETs mine would likely have about a 40A continuous rating. (for comparison, a TZ85 use 3 x 191A FETs on each corner, but when mounted, their pins limit them to 28A. 3 x 28A giving ~85A which is where they get their rating from, despite the fact that the FETs themselves could handle up to almost 600A continuous, 800A peak... No wonder no one ever seems to kill them! :L)
        The parts for this cost about £15 in total, which is a fair bit cheaper than £50 for a pair of TZ85s
        When it's done I'm planning to run it in my featherweight until I get my heavy going; if it gives me any trouble running in my feather than it's gonna be useless in a heavy :L
        In other news, I'll hopefully get my £20 postage back for my polycarb, as I collected it in person at Maidstone. This'll free up a nice chunk of my budget again
          I've got a welded steel grab/lifting mech from an old middleweight someone built and I used in the "heavyweight" I half made at some point you can have for free if you can pick it up. Got some nearly new SLA sitting doing nothing much too if you need them.
            Ohh, I'd be very intrested; I'll PM you.
              The ESC is now mostly complete; needs a few final touches like bigger cables, more caps, heatsink etc, but otherwise is working nicely.
              All the major parts for this project have now been acquired, largely through generous donations from various people (thank you very much to all contributors ). As such, I've so far spent £19, though this'll go up closer to the £50 mark when I've bought all the little things like bearing, high current sockets etc..
              Dunno if I'll get a chance to start the build over Christmas; if not, it'll all have to wait till the summer holidays.
                If you get to a point of selling these ESC's for heavies I'll have one of you as well as one of your ant controllers
                  Got a few hours at home today where I could get the parts for the heavyweight together, and so was able to have a look at the layout:
                  This is becoming less of a low budget Heavyweight, and more of a community Heavyweight:
                  The motors were donated by Dave Lawrie and passed on by Craig Danby
                  The wheels, which were originally on an old version of the Saint, were also donated by Dave Lawrie and passed on by Dave Weston.
                  The batteries and lifter grabber weapon (though the weapon is not in the photo and may not actually be used in this robot) were donated by Harry Hills.
                  And the 2 square meters of Polycarb for the armor came from Jonno for £10.
                  Thank you so much to everyone who've provided parts I hope you won't be disappointed by the outcome :P
                  I now have all the major parts needed to put it together, and it's not likely to be much more than a few days work, so I'm hoping to put it together over Easter and have it at Burgess Hill.
                  It's currently planned to be a larger version of my Fleaweight, Nuts:
                  It's probably going to share the same name; It was going to be called Big Nuts, but that might be stretching the innuendo too far
                  Just working out a way of securing the giant nuts in a way that there's no way they can't come off, whilst being flexible enough to flail properly but without getting tangled. Currently thinking a combination of chains and thick steel cable... though I need to source some good chain first.
                    I'd double check with the EO's to make sure it's all alright (I don't know how heavy those weights will be, nor how fast the machine will spin) just in case it ends up coming under classification as a spinner but other than that, definitely looks good! Looking forward to seeing how this comes together!
                      I would think that this rule may prove a problem with this weapon type.
                      12.2.1 Entanglement Entanglement devices such as nets, fishing line, cables, string, glues or tapes, which require the match to be stopped and the robots separated. (If this occurs the ‘entangler’ forfeits the match)
                        Having asked a few people, the general consensus is that seeing as the nuts will only be a few kilos, and it'll rotate at about 60rpm, it's probably less dangerous than just a robot driving into another. if anyone's seen the fleaweight one fight, it looks ferocious when spun up, but does absolutely nothing when it hits; it looks good for the crowds but is in no way effective :P
                        The entanglement rule was discussed for the fleaweight version, and it was agreed that the weapon is not intended for entanglement so was fine. The flails on the heavy version would be proportionally much small than on the fleaweight one, so entanglement would be less likely. Plus, it's unlikely to stay in the arena long enough to entangle anything :P
                        The bigger concern was making sure the nuts stay on no matter what, as the flippers plus a loose nut may cause trouble. As I say, I'm planning to have several cables and chains attaching them, so that if one breaks, it stays attached till the end of the fight when it can be repaired.
                          Ok, it's the Easter holidays so we finally have some progress! However I only have a very limited time as Richie's in the champs, I'm away after Saturday, and back at uni after the champs, so only have this week to build a heavyweight and get Richie ready.
                          Started work on the chassis on yesterday, as I spent Monday doing some upgrades to the controller and building Richie's new one.
                          Starting with an old elevator frame as a source of most of the steel, I spent the first day just putting together the basic frame and motor mounts.
                          I finished fitting the motors and welded the frame together by lunch time today which resulted in the rolling chassis:
                          I then fitted the battery holders and wedged in the electronics for a quick test:
                          (I really wanted to hit the car... may have to do another video of that once it's finished :L)
                          It's pretty ridiculous.. which is good as that was always the plan :P Spins nice and quick, so should look pretty spectacular once the flails are fitted.
                          Took the electronics back out, added some extra cross bracing and fitted the armour. This is where I've got to now:
                          Just needs a bit more bracing and then the main body is done. Still need to fit the outer ring and flails, but with any luck I can get all that done tomorrow and make this a 3 day build, though I still don't know what steel I'm using for the ring as it has to be pretty solid.
                          Currently weighs around 65kg, so hopefully the ring and flails'll bring it up.. If not I'll just have to keep adding more bracing and armour
                            Big Nuts entered the arena for the first time on Sunday, albeit without any flails fitted. It was incredibly entertaining to drive despite not actually doing much yet. I put it in for the last melee of each show, however the link wasn't in properly for the second one and fell out almost immediately in the second show (another thing added to the to-do list), so only really got oned fight. It spent it's time barrel rolling, somersaulting and spinning around in a suitably odd fashion, but it all seemed to work fine and didn't get stuck on it side as I thought it might (until one of the battery packs came disconnected towards the end), and managed not to catch fire or go crazily out of control or anything like that.
                            This was really it's first test after being completed properly, as I'd blown the ESC whilst trying things out with the circuits shortly after the first test video above, and didn't get around to fixing it until I was back at uni so had no where to test it until the show.
                            After fitting the ring around it and yet more bracing, I got the weight up to 83Kg, but am hoping to bring it closer to 100 with the addition of the flails and maybe a bit more armour. I think the total cost up to this point is getting close to £50 (I bought a few nuts and bolts and a few extra connectors at some point), but still not over budget yet!
                            It'll hopefully be running at Portsmouth next weekend in much the same state as it's in now as I can't fit the flails until I'm back home for the summer holidays. Hopefully will get it in a few more fights and find any more bugs that need ironing out.
                            It's good fight feature's in Harrys video of the event about 31 mins in:
                            https://youtu.be/wO_GAOLGL2U?t=1870
