New featherweight (DMBLBIT)
    Should the orange and red wires go to the +ve and -ve of the receiver? Or to each other?
    Thanks, James.
      https://www.youtube.com/watch?v=f_Xo...ature=youtu.be
      Got it working in the end. Just need to fix the wheels on a bit better now........
        whoahahahaha, I think you might be right . Good speed though.
          Looks great, nice speed and very compact. All i would say is protect the wheels if you can, they're food for an axe or spinner right now. Oh and fix them on properly. .....obviously.
            Yeah, planning on having another layer of armour outside the wheels. Need to find out what weight I've got left to play with. There's no size limit on FWs is there?
              From what I know there isn't. Only antweights and heavyweights are restricted within their dimensions
                There is a size limit. to featherweights - it's the doorway...
                • #23
                  Ah the good old days of wheels falling off. Used to happen to me all the time on my old wiper motor bot, and for the first wee while when I transitioned to drills. I kinda miss it; damn improved building techniques!
                  • #24
                    any tips on keeping them on then?
                    • #25
                      Grub screws, circlips, collars/collets, nuts - whatever best suits the design and how the wheel is mounted etc
                      • #26
                        You might want to try adding a layer of armour to the outside as well as an outer bearing along with that - I think that might be very handy for this kind of design, and definitely will reduce the stress on the wheel axles I'd imagine. Would also help keep them on too!
                        • #27
                          Wheels sorted. Made it into a thwak bot for now (10kg before i added that).
                          Planning on making a range of (boring) weapons to be bolted on the front including a practical scoop. Not sure I can fit anything active into 3 kg.....
                          https://www.youtube.com/watch?v=-XAA...ature=youtu.be
                          • #28
                            Got problems charging. Using an Imax b6ac charger and a turnigy 3000mah 22.2v (6s) lipo.
                            Error message reads "low voltage".
                            Battery voltage is 14v on my multimeter. I'm worried I might have knackered some cells in there...
                            Obviously I now won't use it until I know what's going on. I'd it something stupid I'm doing wrong or is the battery done?
                            James.
                            • #29
                              If it's reading 14v it's severely discharged. Works out to 2.3v/cell assuming they're discharged evenly, which is a good way beyond what they should be. A high end charger might be able to resurrect it. Have you tried Charge or Storage instead of Balance? The Imax might happen to be okay with the lowlow voltage in other modes. It's very possible the pack is permanently damaged and trying to force charge into it could be dangerous, so I would put it outside and keep a very close eye if it does accept it. It might also be wildly unbalanced so only charge to say 3v per cell and then switch to balance.
                              Not very recommended but you might save it. Looks like overdischarge, easy enough to do but you won't do it again. :P
                              I'd suggest getting a LiPo alarm/voltage reader for a couple quid from Hobbyking. Allows you to stay on top of the voltage and stay above unsafe.
                              • #30
                                Yeah, tries the other modes with no luck. Don't think my charger up to the job.
                                To do what I did its it just a matter of running it until the battery is completely flat?
