very nice drives
Flow - general changes & upgrades
Long time no update
Lots to talk about, so bear with me.
Firstly, Flow.
When we put Flow in the arena at Newcastle the regulator was misbehaving. We tried everything to fix it but couldn't
For Stevenage we got a brand new Trevor reg fitted and it worked fine, besides a little leak in the base. To fix this we blasted it through with gas to cool it, tightened the fixing and let it warm up again. Once in the arena it was armed up and the flipper arm began to lift :P. After some investigation we found that the manual override on the self right valve was knocked into the open position, we closed it and it ran beautifully in the final fight. Flipped over 20 times and still had half a bottle left by then end! The pressure was turned down quite far so it wasn't as powerful as it should've been, but itll be running at max power for Bluewater. Unfortunately not had time to fit the Astros yet, so still running the 550s, but they will be fitted along with TZ85s and running on 6S rather than 4S after Bluewater.
Ricochet.
We finally figured out what was causing it to cut out, it's the old motors drawing too much current for the XXL to cope with, hence it stops for a moment and takes off again seconds after. Because of this I've regrettably had to retire this version of Ricochet while I figure out how I want to rebuild it better than it was before.
RPM
RPM had a good run at AWS 44, taking second place to Anvil. After that the second hand 3S Lipo was truly dead, ao I ordered a new one and waited. And waited. And then, days before Stevenage, it arrived. But it turns out it had a break between cell 1 and 2 in the pack, rendering it useless. I borrowed Headbangers battery (thanks Dave) for some demos, and blew an ESC, so had to sit the comp out. New bulkheads have arrived, and shortly going to order some new ESCs, so RPM will be back and working soon.
I'm getting an antweight done for AWS 45 in November, so I might post that here when progress is made. I also have a beetle design I intend to have completed for the next Robots Live event, which I think will be Whitwick next March?
Anyway, sorry for tl;dr post. Thanks to all who helped out, I really appreciate it. Hopefully see most of you at Bluewater on Saturday
It could work provided the ESC's don't share any motors between them, if they do it might get a bit toasty :POriginally posted by daveimi View PostSounds daft but for Ricochet could you split out the servo cables and use a second XXL etc? Would allow you to keep the robot as is if you're happy with it.
I had considered putting in my spare TZ85s to run them, but the damage to the motors (bearing in mind they've been in two robots and are now 3 and a half years old!) has meant that they've started to struggle under load. That and it was always too slow for my liking, time to make it faster
