Team Asgard
  • Team Asgard
    Pre season testing videos from today at the team Asgard technology centre (why not jump on the band wagon).
    Db10
    http://youtu.be/vbAxJEGaTTo
    (Don't watch if you are offended by bad language - tut tut Callum).
    Testing is important see if you can spot the deliberate mistake.
    Ts3
    http://youtu.be/DUxHVMoaawE
    Sweet testing videos. Be interesting fighting DB10
      Poor old db5!
        Yes it's even more mashed now, ti sides are bent and buckled the base plate is cracked and the threads holding the top on are pulled out.
          Db5 got well and truely bummed! Some interesting robots for this years champs! Be good to see how your disk does in db10s fights
            Been getting some driving practice today, it's good fun to drive.
              Did you go for the ti disc in the end ed?
                No got the steel one on
                  CAD work started for next year and some parts ordered. Not going to make major changes, just some small improvements to improve reliability, armour and the weapon(s).
                    New parts for db10 machined for next year already. Not quite finished yet, need to remake the axle from titanium and fix the gear to the motor shaft.
                      Have you got a battle going on with Grant, as to who can have the gearbox with the most curves?
                        It's inspired by grants a little, but mine should be done before zero hour!
                          Spent a few hours at work over the weekend, lightened some parts and made some new parts for DB10. Including rubber mounts for all components, to help reliability, new titanium disk shaft and new wheels. Also started the mods to the bulkheads, nothing major again some tweeks to improve access and reliability.
                            Do you still have enough weight to make your front bulkheads solid? Binky made light work of the pocketed sections at the champs.
                              Yes, that's the plan or part of it.
