RAM (lift em up mk2) Featherweight
Are you intending to try entering this into the champs? If so you need to get rid of all the right angles on the uprights and slope your side and rear armour to help reduce the catch points for spinners.
There is little you can do about the the ground clearance for flippers with a design like that. Also watch out with the weight of your Hardox blade. If its that whole front element I can see that easily weighing 4kg, possibly more.
