For a while I've wanted a machine that is very destructive. Bitza MKI, MK II and Splinter didn't really strike fear into opponents hearts and should Crux come into being that's what I'm hoping it'll do. For a while now I've been toying with the design for a large diameter disk similar to the heavy weight Nightmare, but with a couple of variations. I'm thinking of have a disk around 500mm in dia spinning at 3,000RPM (if it was just over 12,000 it would break the sound barrier
). Realistically it'll be about a year until it's built so I'm putting the designs out there in the hope that I'll be able to refine it and troubleshoot some of the problems before it enters the arena.
Here's my initial, very rough idea:
Right off the bat I've got 2 problems I could do with some solutions to firstly how do I fix a relatively thin disk (working on it being 5mm ali) to a large shaft.
My first thought was to cut a square hole in the disk and make some sort of flange like the one above. 4 x M10 bolts would clamp the 2 flange halves onto the disk and a keywayd silver steel shaft would locate into the flange. I want the shaft to be chunky, I was advised 10% of the disk dia works well but a 50mm shaft seems a lot, the one in this model is 25mm
I'm considering using some extruded ali section for the frame. I've watch the Nightmare Warhead fight a couple of times and clearly this sort of design is vulnerable to horizontal spinners so if I can source some large dia tubing I'd like to make some simple wheel guards. I was considering cutting into the leg supports and swapping a section out for springs from a garden gate so the leg could be knocked away by the horizontals then return. If I was going to do this I'd have to have supports either side of the disk like Backlash had as the legs would fold out of the way under impact. This would rely on the centrifugal force of the the disk spinning to prevent it toppling over. Not sure this is the best way around that problem, but I've got a year to nail the design down.
If you've not seen the Warhead / Nightmare fight it's well worth watching
http://www.youtube.com/watch?v=58j1MypGJDA
I particularly like the insightful commentary at 1:14 :P
The second issue is with weapon drive. I'd like it to be direct drive to remove the inherent weakness of using belts and chains but there's some concern the motors would get trashed.
http://www.youtube.com/watch?v=V0LYpIekDxE
