I have 2 x Gimson GR01's running on a Sabertooth 2x12. If you look at my build diary there's a video of it running up and down my kitchen  It's had some hammer and is fine, they have a thermal/current cutout that will cut back in after it's cooled down.
Obviously a 2x25A is beefier but when my whole robot was made with parts from the bin it's been fab!
The problem with using individual ESC's like the botbitz is that you need to fork out for one for each motor, and then need a way of mixing fw/bk and lft/rgt to give you car type steering. Something like the Sabertooth does that for you, or a Scorpion but they're expensive.
Some expensive handsets will mix but they do weird stuff with limiting current to 60% like the DX5e's do with the Turnigy 85's etc. If your after something easy to use just get something that runs both motors off one controller and mixes for you.
 It's had some hammer and is fine, they have a thermal/current cutout that will cut back in after it's cooled down. Obviously a 2x25A is beefier but when my whole robot was made with parts from the bin it's been fab!
