Spur II build
  • Spur II build
    Well this was Spur. It was my first featherweight and in general happy with it
    Good points
    - Chassis was solid. It used 10mm HDPE but the corners were joined with angle iron and had a 3mm base. You didn't want to drop it on your toe!
    - Traction. It used 4 drill motors with 100mm blue wheels with mountain bike tyre. The tyre had a nice open tread and wear rate was low
    - Its a lifter and the linear actuator was very powerful
    Bad points
    - The wheels were exposed so vulnerable. It got slipped once landing on a wheel wrecking the gearbox
    - Linear actuators have no give. So landing on the forks meant the forces had to go somewhere. Generally into bending the forks
    So after getting my axe robot into a working state, and learning a bunch from steel chassis bots, I have decided to build a new Spur imaginatively called Spur II
    I wanted to keep the bot nice and small. This allows me to use weight in a more flexible manner.
    Key objectives
    - good traction
    - protected wheels
    - strong lift but able to withstand shocks i.e. flips
    - able to go full combat
    Re: Spur II build
    Steel is more unforgiving so went for drawing and templating the steel before cutting
      Re: Spur II build
      So this is the basic layout
      Its tight inside but enough space for the important bits
        Re: Spur II build
        I've got the steel templates cutout
        Currently 4mm Hardox sides. The chassis plate is 3mm but looking to move to 4mm as well
        Just need to buy a welder to put it together
          Re: Spur II build
          The lift motor is from an AEG 18V cordless drill I picked up cheap from ebay
          Its a monster but the gearbox is 2 speed and general quality seems very good
          I'm building this on a self contained frame for maintenance. It will chain drive the front end lifter mechanism
            Re: Spur II build
            have you left enough space for the esc's
              Re: Spur II build
              Yep - 3 TZ85a. They line up nicely under the battery
              I might move one under the lifter motor. Enough wiggle room to decide in a bit
                Re: Spur II build
                How is the AEG 18V getting its power to the forks? There seems to be very little space
                  Re: Spur II build
                  Chain and sprocket
                  A 14 tooth sprocket on the motor (welding onto the shaft)
                  The lifter will be a 17mm shaft running in needle bearings with sprocket welded on there again
                    Re: Spur II build
                    So will the chain go around one of the Gimson drive motors?
                      Re: Spur II build
                      Yes, might need to get some guides in place but the larger sprocket on the lifter helps and the rotation of the chain is minimal
                        Got the basics of the chassis welded up.
                          That looks familiar.
                            Well done some welding. Internal bracing is in. This is the basic layout. Can squeeze 4 GR02's , 1 huge lifter motor and gearbox plus a decent sized battery. Will have 3 hacked TZ85a's.
                            The control for the lifter is going to be electronic through a Arduino Nano. I've been developing the code for axe control and decided that a few small mods it can be used for a lifter including torque control. This allows me to remove the need, and weight, for a mechanical torque lifter. Shame I decided this after I bought the mechanical control
                              So that's what that shaft was for. I did wonder why you only needed one.
