Team Psyclone: The Uprising (Of Build Diaries)
  • #31
    Yeah sure their m5
    • #32
      ^ Thanks, that helps quite a bit.
      So, I've got everything but the tube that goes through the middle of the big sprocket bookmarked, I just don't know what diameter to go for. Is the diameter in centimeters or inches? It's not clear on the website.
      • #33
        The tube that I use on mine is actually a 12mm silver steel bar from Technobots:
        http://www.technobotsonline.com/silv...3mm-33173.html
        I then cut it to the appropriate length (~100mm) then drilled a hole in either end and tapped it to take an M5 bolt, just to help hold the whole assembly together. There are also 12mm needle roller bearings pressed into the bulkheads.
        The output thread/shaft on a drill motor is 3/8"UNF as mentioned. In metric this is approximately equal to 9.52mm. So what I did was drill out the small sprocket to 9.5mm, screwed it on to the drill shaft (it caught the thread very lightly, but not great) and then fitted the reverse thread screw to compress it on. Seemed alright but after one test fire, the sprocket came loose. I've since welded the sprocket on.
        If you don't have access to a welder, the next best option would be to drill the sprocket hole out to 9mm and then use a 3/8"UNF tap to thread it and screw it on to the drill motor (this is effectively the same as screwing a blue wheel on) then secure it using the reverse-thread screw. The grub screw option isn't really effective for the 8-tooth sprocket as once you've drilled it out to fit on the shaft, there's not a whole lot of material left to tap.
        Hope that helps; usually easier to explain these things in reality than across the internet. More pictures of my axe mechanism can be found here if you want a better look or alternative angles: http://s31.photobucket.com/user/ayrs...?sort=6&page=1
        • #34
          Right, I sort of see. As you said, it would be easier for a live showing, but I've been too preoccupied with current events to get down to any of the... Events. The pictures do help quite a bit, and I will probably learn a bit through them. I'll have a good ponder about it tomorrow, but as of now, I must be off to bed.
          • #35
            Got myself a nice cheap Tap and Die set, so now, I believe, I can focus on saving up for parts. The Tap & Die set comes with M4, M5, M6 and M8 Taps and the same size thingies that make screws.
            Basically, the Axe is going to be at the back of the robot, and swing overhead, making it so it can hit front and back, with a pickaxe style blade. Either that, or do it the other way, so the wedge is the rear, and have it rest on that. Maybe do a scythe looking blade there too. I believe that wouldn't made it imbalanced, so I may end up with that. I can whip something up in paint, if my explanation is a bit too weird/stupid.
            • #36
              So, having a scout around eBay, I found a pretty nice 24v, 12 tooth (I think, has the sprocket on it already) Scooter motor, supposedly goes up to 2750RPM. I couldn't find any motors for driving around that voltage, apart from Gimsons. If I have no other option, I will use a drill motor for the axe, or something similar.
              Would it be ill-advised to go with a brushless axe motor, or should I stick to the usual?
              • #37
                Those thingies are the dies...
                • #38
                  Oh yeah... I'm an idiot, haha
                  Anyway, since today is nice, I'll be filing down the machine, so all the aluminium panels line up with the bars. And so it's a little more even all around. Then, I need to save up quite a bit of money.
                  • #39
                    Just a quick update, I got a nice 18v DeWalt Drill, old, from my uncle, but it works beautifully. With that, I drilled a few holes, and bolted down the side panels (Which weren't held on great).
                    Would it be possible to use a timing belt and timing pulley with the axe? I think it's easier, and a bit more stable than sprockets. though I would need to weld it to the shaft. Basically, I need to save a lot.
                    • #40
                      yes that will work
                      • #41
                        Right, thanks.
                        How would I attach the shaft to the robot itself? Could I use rotating bearings either side of it to hold it in place, and use a couple more closer to the timing pulley?
                        EDIT: Ignore that, I've just realised that the pulley can rotate on a fixed shaft.
                        • #42
                          Popping in for another question: Though I intend to use two motors with the hacked TZ85as, is it possible that they could run two 12v motors each? Or would that be too much stress?
                          • #43
                            They should handle two standard drill-size motors easily, as they do in our setup. I have never even felt them get warm, either when we were running 12v motors at 18v nor now, with the motors being 18v and the gearbox ratios being lower.
                            • #44
                              Righty, Thanks. So, I've spent a couple more hours in what seems to be a blazing sun today attaching a little scoop/wedge to the robot. pretty well held on by my standards, but I just can't get it to bend, so that it's flush. It just makes the robot's front stick up a couple centimetres.
                              • #45
                                How would I fit a needle roller bearing to the robot, so that the shaft spins? Or, how would I fit the shaft to spin, through 4 20x20mm bars?
