Splinter
    Re: Splinter
    I'm looking forward to seeing how those 2 fan motors will perform! Theoretical 8hp!
      Re: Splinter
      Wood gums up conventional spinners and absorbs the impacts. A saw blade would be required however no one fits those these days
        Re: Splinter
        We found even wood saws to be pretty ineffective since they require constant pressure at a certain amount. In fights it's often all or nothing if the blade is statically mounted, so the blade ever digs in and gets stuck or breaks.
          Re: Splinter
          What batteries are you running, by the way?
            Re: Splinter
            Wood , mother natures own carbonfiber.
            Depending on kind of wood and treatment, not to be underestimated. If 18th century ships of the line could stand up with oak and teak armor against heavy cannons, why would a robot do less?
            Warrior, the first British Ironclad, used 18 of teak to back up the 4.5 of iron armor. (incidentialy, she's at berth in Portsmouth...)
            The Series 7 veterans here have seen how wooden armor destroyed an Etec.
            The Dutch Robot Twister, using a heavy triangular sledgehammer directly mounted on the Etec against Brutus Maximus. The wooden armor of Brutus maximus stood up well, especialy compared to the more common ali and/or polycarb armored machines.
            Just think about the difference in cost... Plywood vs Etek....
              Re: Splinter
              Well BitzaWood is MDF, which I don't think will last too long, but proper hardwood is seriously strong stuff, it also makes a good ablative armour.
              @Ellis, we're using Li-Pos they're the only thing that can give us enough amps for the fan motors.
                Re: Splinter
                Ah cool, with a battery that can feed those motors what they want the machine should indeed be insane.
                Videos?
                • #23
                  Re: Splinter
                  Hopefully soon!
                  • #24
                    Re: Splinter
                    I asked about being able to fit a saw blade in the wooden class discussion and Grant said they wouldn't allow them as they are not all one piece. So that may translate to the champs... not sure.
                    • #25
                      Re: Splinter
                      The problem is that the sharp tips are braised on and break off too easily.
                      The plan was to test out BitzaWood at another RC event (not the champs) when it had the saw blades, but in my own tests most just broke off and the blades proved quite ineffective.
                      I can always put them back on for a later date test.
                      • #26
                        Re: Splinter
                        blades like this might be good :
                        http://www.ebay.co.uk/itm/Vanguard-Powe ... 2325807569
                        Its not Bi-metal type, ie. its a single piece of HSS....just a thought...
                        • #27
                          Re: Splinter
                          Would milling cutters work or are the teeth on those just brazed on too?
                          • #28
                            Re: Splinter
                            Doesn't matter. Any cutting tool need a stable part to work with. With robots, nor the base, nor the to be cut object are stable.
                            Point in case, Dead Metal, there the jaws made the 2 a stable base.
                            • #29
                              Re: Splinter
                              As much as I'm enjoying the discussion about which weapon would best take apart my robot :wink: I've got a problem.
                              Each motor runs fine on it's own (better cable sort that out) but when I run both together I get smoke coming out of each motor.
                              The only thing I can think is that when both are running it's likely they'll be starved of amps but I can't see why that would give me a smokey motor.
                              Here's the current set up:
                              1 x 2200 mAh 3s Turnigy LiPo rated at 20C constant, 30C burst
                              2 x TZ85a fused at 80A
                              2 X Car fan motors. I haven't got the exact numbers for them but I guess the stats are close to EV warriors which have a stall current of 100A
                              Any thoughts?
                              • #30
                                Re: Splinter
                                Check the motors dont have an earthed case (put a meter across the case to each terminal/wire) I thought with a wooden robot this wouldnt be a problem, but it looks like your using the same bolt to go through both motors, which could cause a short if the motor cases are earthed.
