Update - Post champs strip down
Not an overly successful champs for me due to a few let downs however it was a fun champs none the less I enjoyed myself and it was good to catch up with everyone.
Spent a couple stripping down boner this evening to see what was good and bad post champs. At the end of the final white board, the drum and drive didn't work and it was essentially dead in the water.
The good
- The batteries are all in good condition although I wouldn't believe the figures that turnigy quote for their nano series. Divide the C discharge ratings by around 10 and you have the genuine figure
- The turnigy 85a speed controllers that I reprogrammed are still in one piece and work well. I can easily see these being the standard for featherweights now
- The body is all in one piece with no real damage bar the self inflicted damage on the top after it rotated into the drum
- The drum spins just as freely as ever, in fact better than it ever has
- After replacing the brushless motor shaft it's still spinning perfectly
- I didn't burn out a brushless speed controller!
The bad
- The gimsons........well I managed to nacker 3 of the 24v motors, all three went "crunchy", sounded odd and then finally nackered themselves (in two cases they went bad before they had even seen battle!). I poured the carbon brushes from one out of the cooling holes of one of them. The gearboxes are still in one piece and rotate freely enough. I get the feeling that the motors are no good being hard mounted with the all metal gearbox, it's basically all too stiff for what boner puts it through (vertical shocks)
Pics to follow.
The good
The bad
Pics to follow.
