Manta- Team Shock
  • Manta- Team Shock
    We've been working on this very slowly over the last year or so and have finally got to the stage where we have everything and something to show. Manta will be making an appearance early next year alongside Maelstrom
    Here's what we have so far;
    Weight: Projected weight so far just under 100kgs
    Length: 750mm
    Width: 700mm
    Height: 400mm
    Drive: 2x Bosch 750's with custom gearboxes on 125mm blue wheels
    Speedo: Wotty 360
    Batteries: 3x 8s A123 packs
    Weapon: FP flipper with 80mm bore, 150mm stroke ram fired by 2 burkerts, 2, 2kg buffer tanks, one main 2kg tank.
    Chassis: Waterjetted from 4mm Hardox.
    Base with motors, gearbox plates and ram after waterjetting
    Chassis tacked together without the flipper and with ram and buffer in place (ram will be shortened by 50mm).
    With flipper resting in place
    Re: Manta- Team Shock
    Lookin' epic man :shock: !
    Nice to finally see it, as you know I've been pestering you at every event about it !
      Looking great! Gearboxes look strangely similar to Eruption's You seem to be going for a similar pneumatic setup as well so hopefully it'll flip well.
      I'll be interested to see how you fit it all in. Going by the dimensions it's considerably smaller than Eruption and that's pretty tight for space inside!
      I'm assuming we'll finally get to see at an event around mid 2015? :wink:
        wish I could get my hands on some of that material
        Looks really solid - hope you put in some pictures and details of the FP set up, it will be interesting to see how you go about it.
