Galactus II
  • Galactus II
    First, sorry by my poor English.
    Well, after the last robo challenge we get much more experience in combat. Galactus had problems with the floor of arena, the skids were stuck between the junctions of the plates of the floor. /One problem of build/.
    We obtained great results with our relation armour/weapon, Galactus had only scratches (less in the fight against Drumroll that galactus had the biggest damage).
    Our biggest problem was with the teeth...all broke, the teeth had 10(6mm out)mmX15mmX170mm...with 4mm of of depth in drum, stuck with 4 screws M5. But the termical treatment result in an VERY HARD steel.
    Now, Galactus is ready for more one challenge.
    With a new drum (with the same diameter 70mm), but with new teeth(with 15mm(9mm out)X25mmX170mm stuck with 4 M8 and a best termical treatment.
    The locomotion have now 2 new motors and gearbox, resulting in an more fast drivetrain. Of ~550rpm to ~850rpm, was used a core of the gearbox GR02 24:1 of Gimson.
    http://www.youtube.com/watch?v=CCiTTe2IIRc
    Now, waiting for the next Robo Challenge...
    Oh, Rabid...Rabid is coming...
    Guilherme Ferreira
    Re: Galactus II
    Looking good
    What is the thickness of the aluminium plate on Galactus ?
      Re: Galactus II
      Hi,
      All 20mm, the top and bottom have 5mm.
        Re: Galactus II
        Looks really good! Looking forward to fighting it... What's the weight and maximum speed of the drum?
          Re: Galactus II
          Hi
          ~3.5Kg, real 12.000rpm with 4S LiFePo...~2.5s to obtain the maximum rpm.
            Re: Galactus II
            Thats pretty impressive! slightly heavier then mine, but a tad slower by 1500rpm.... what motor you got on the drum then? Ive found mine gets a tad warm on continuous running.
              Re: Galactus II
              The normal is that brushless inrunner warm MORE than the outrunner...more normal is when don't exist air in...the unique form of dissipate the hot is by thermal transmission between winding and armour.
              Mine warm too, but my motor is stuck with 2 blocks...the transmission of hot is made to the all robot...
              For now i use the Turnigy XK4074 1400Kv, but i waiting to put the XK4082 1600Kv.
                Re: Galactus II
                It reminds me of touro, especially the way it slides and moves. You have a cool robot!!!
                  Re: Galactus II
                  Very impressed Guilherme!
                  Going to be a serious contender.
                    Re: Galactus II
                    Hi PJ,
                    I hope that you're right
                    Now is training some tricks...
                      Re: Galactus II
                      Wow it looks great Guilherme!
                      I love galactua 1 at the champs earlier this year and it put on an amazing performance, hopefully the new mounting for the teeth on the drum will work a bit better than last time, I remember bits flying off after every hit and even finding a bit in laser II!
                      Just wondering what ratio the drum is running on?
                        Re: Galactus II
                        Hi,
                        Tnks for love Galactus =D , the ratio is 1.5:1.
                        Old Galactus, had a powerful weapon but one weak link...the tooth...
                        Guilherme Ferreira
