Due to opening a pub I just didn´t have the time to work on Brutus . After the summerholiday I got some sparetime to start and finish Brutus .
I´ve got a question ; I´m using karttyres for Brutus . Who uses also karttyres and got a good idea instead of air ... ?
I'm fairly sure Tornado used go-kart tyres, and they seemed to do very nicely. I'd guess some thick/solid foam could help keep them inflated, but I'm not sure what people use specifically...
Cut them to fit around the rim and then rammed it in hard. Worked like a treat with punctures to the rims (shame the rest of the bot had issues). It was a recycled foam made from small bits of different foams glued together (cheapest they had). They did weigh a fair bit when all was said and done though.
I got them to the size of the outside of the tyre so they were a bit oversized but not by much at all. The recycled foam was fairly stiff and took a good few bent screw drivers, swearing and hurt fingers to get all 4 wheels done but I got it in. I'll see about digging one out when I get home from work and take a picture or two.
Depends on where they are located I guess. Tornado and Merlin are both protected from side impacts (from memory) whereas I rather foolishly had them on the outside of the bot so they had to be run flat.
