Massacre - FW
  • #31
    Re: Massacre - FW
    aye, its going to be proper fun.
    • #32
      Re: Massacre - FW
      Just wondering for absolutly no reason, how high is that bar off the floor?
      • #33
        Re: Massacre - FW
        erm... if i say 200mm willl you belive me :P
        • #34
          Re: Massacre - FW
          It has to clear the wheels so that would be 80mm bare minimum; that gives 5mm clearance on the wheels. But I think it will be closer to 90mm myself.
          Going great by the way! This is a really complex build and it seems to be going perfectly so far!
          • #35
            Re: Massacre - FW
            My whole robot is only 70mm in the body
            • #36
              Re: Massacre - FW
              Turisas? 70mm tall? Oooooo :twisted: thats good!
              • #37
                Re: Massacre - FW
                Turisas? 70mm tall? Ooooo :twisted: Thats usefull to know.
                With 100mm wheels? Or is it not invertible?
                • #38
                  Re: Massacre - FW
                  or with 75mm wheels (or is that the 50mm wheels Matt :P )
                  • #39
                    Re: Massacre - FW
                    Just something to watch out for Mattsdragons - if your robot's 70mm tall and using 75mm wheels in vertible then your likely to have a few issues getting stuck on the arena floor. Although it's the flattest floor of any to drive on, the hardox panels can warp slightly with heat etc and so 2.5mm ground clearence all over may get you stuck at times.
                    • #40
                      Re: Massacre - FW
                      Its using 75mm wheels, if I get stuck then ill just have to deal with it
                      Got nothing to hide
                      • #41
                        Re: Massacre - FW
                        Its not so bad. If he does get stuck Binky will soon free him
                        • #42
                          Re: Massacre - FW
                          If its working after 2 qualifying rounds, I hope not
                          • #43
                            Re: Massacre - FW
                            Got nothing to hide
                            That's a bold strategy. By the time the robot has been in a battle it's unlikely to have an even 2.5mm Clearence both sides. It pretty certain you will get stuck at some point. Wy not make a weapon to beat your opponent. Surely a brick with no power can't fight, it just gets hit...
                            • #44
                              Re: Massacre - FW
                              I was only having a quick guess but its a 4mm clearence and with the sloped areas at the back to get of wedged plus it bein 6wd and compact I shouldnt really have an issue
                              • #45
                                Re: Massacre - FW
                                You could take a strip of inner-tube and screw it it the out side of the wheel. That would raise it up about 2-3mm. Also is cheap/free if you can find a punctured one
