Re: Team Microbots Build Diary
im 99% sure that is a claw i had made a while ago and if it is then its not ti its all mild steel
I also picked up Metal Beak's beak from Jamie at the event:
Lovely, 20cm long, 1.5mm welded Ti construction, 2.5mm Ti point, and it only cost a fiver
![/quote]
. A new 6WD full body hammer is required, smaller, LiPo powered, and lotsa steel! Will be keeping the 40mm HDPE too; it may not be the strongest stuff, but no spinner is going to go through that, the best both 720 & Troublesome did was take about 2-3mm off the side. Add a steel plate onto that and bingo, steel box of inpenetrability
