got the motors, 4qd speed controllers and interface, a pneumatic ram and reservoir
The motors if my calculations are correct should do about 14mph (2900rpm, 8-1 gear ratio, and a 330mm wheel). The pneumatic ram it a 12bar 100mm bore, 125 stroke but i might go for a electric lifter/axe combination instead depends how the test with the pneumatics go and i will probably use 30x30x3mm box section for the main chassis
also cant decide which name to go for so i should probably put it to the vote at some point lol
(would have added some pics but the board attachment quota has been reached)
