Team Fire Force FW build
  • Team Fire Force FW build
    Hello,
    I am starting my very own build diary for my featherweight in progress.
    I made the team name up when i was little so forgive it for sounding cheesy
    last week I got the drills from argos (the more expensive £15 ones.)
    they do 600rpm, is that more than the £12.50 ones?
    It will be all wood (18mm plywood and oak so its tough)
    there are pictures on my picasa account
    BTW here is somthing really cool
    check this out enter your post code and watchhttp://taxi.ba.com/
    try with the photos
    https://picasaweb.google.com/1097920708 ... 8715396834
    :l
    Re: Team Fire Force FW build
    Your link says page not found
      Link not found.
        here
          i just had an idea.
          skate ramp!
            Looks good
            Are sure that the wood is going to be strong enough?
            Also, how are u holding the wood together?
            Looking very promising though!
              Ply wood is very strong so it should be fine, I like the look of your motor mounts you should remove the wires going to the drill motors and replace them with some thicker wire or they will limit the current going to the motors. Are you using the drill batteries and what esc? And the £15 drills are the same as the £12.50 drills, they have just increased the price again :sad:
                the plywood is 18mm s its plenty srong enough.
                the mounts are oak.
                speed controller are botbitz when i get round to ordering them
                oh yeah and drill batteries might be used till i upgrade
                  i'd bring some spare pannels to events if i were you.
                    18mm ply is strong enough make sure its mounted and secured together correctly
                      you wouldn't believe how much wood i used on it!
                      about 1-2mx50cm.
                      so i.don't have enough for spare.
                      i know its plenty strong enough.
                      i think its huge.
                      45x30x9.
                      it weighs 4.1kg like that and my aim is 8kg
                        Actually looking pretty good mate! Looks very neat and nice. I have to say, 18mm ply may stand up to non-spinner combat, but it won't much like full combat. I am guessing you don't intend to enter full combat anyway. Don't be fooled by the stresses involved even against ram-bots, though; a wedge corner doing 15mph with 13.6kg behind it will do damage.
                        Looking forward to seeing how this turns out.
                          it only looks good because my dad took over most of it
                            Ok because i was trying to save a new thread I posted my stuff in my GS links section.
                            PLEASE SOMEONE ANSWER THIS
                            anyone I really need help and want to order ASAP.
                            Originally posted by archie2000
                            ok so I wonder if anyone can help with my GS order.
                            1stly the servos with carbon fibre gears, (worth a try?)
                            Servo moding failed last time and I think it could only get worse with the carbon gears.
                            seccondly, I have found M5X5 grub screws on the site (I know M5X8 is ideal but they dont sell those)
                            could I use a nylon M5 screw. screw it in and cut it down?
                            help appreciated
                            Archie
                            Thanks in advance (hopefully)
                              plastic bolts are not a good idea. happy?
