My first featherweight
  • My first featherweight
    Type: Dual wedge
    Motors: 4x 12v drill motors (got)
    Speed controllers: 2x scorpion xxl
    Batteries: 12v drill packs (got)
    Armour: 10mm HDPE on sides, 6mm HDPE on top and bottom (got)
    TX/RX: http://www.giantcod.co.uk/gianitcod-...-p-403779.html (got)
    rough arangement of internal electrics -speed controller (likely to change)
    http://s1246.photobucket.com/albums/...t=P3210010.jpg
    Re: My first featherweight
    2 scorpion xxls?
    why?
      it's 4 wheel drive
        dont they have 25a cont though?
        with 45a peak
        am i right in thinking one would be enough?
          well then I will have a spare if something happens to the first one
          Edit: they only have one input so I would be controling 4 motors with 1 channel
              They are definitely not 1 input, first line of the description reads:
              The Robot Power Scorpion XXL is a flexible high-performance two-channel motor controller
              So you want 2 motors per channel Left in one and Right in the other.
                Thats what I mean only 2 motors per channel
                  i'm pretty confident it saying youll be able to run 4 drills on an xxl, they have current limits on them i believe so should cut before you damage it
                    everyone saying I can run 4 motors of 1 scorpion put a tought in my head, could I run 2 motors off an electonize 30a? It would cost less.
                      yeah, i run 4wd with electronize 30 and its fine
                        Yes, but you'd need 2 since the Electronizes are not dual motor controllers.
                          I understand that I would need 2 but 2 electronize 30a costs less than 1 scorpion xxl
                            hence why i use em
                            the xxl is better though
                              an xxl is much better than 2 electronize however the elctronize can be good for your first bot
