HAZARD 2
  • HAZARD 2
    Hi i am going to start a build diary on my robot hazard 2
    Re: HAZARD 2
    It would be interesting to know the speed of it:
    Its really fast It runs off 4x50:1 gear motors with 32mm wheels and a 180mah battery
      Re: HAZARD 2
      I've got an equation
      to calculate the velocity you do pi (3.1416) times the diameter of the wheels times the rpm
      if you have a robot with 10inch wheels and 300rpm motors that is 8.9 MPH
      but to calculate the rpm of the not you do velocity divided by pi times diameter
      hope this helps
        Re: HAZARD 2
        it uses some 180mah lossi bateries
          Re: HAZARD 2
          some pics coming slightly later
            Re: HAZARD 2
            Think I have a picture
            Might not work
              Re: HAZARD 2
              Thats failed hasnt it
                Re: HAZARD 2
                how do I add pictures
                  Re: HAZARD 2
                  does this work?
                  https://picasaweb.google.com/1097920708 ... 9829987602
                    Re: HAZARD 2
                    most people upload to photobucket then copy the img codeinto their post (this embeds the image)
                      Re: HAZARD 2
                      yeah I cant get onto photobucket
                      Can you still see the picture through the link?
                      Thanks for replying
                      I was kinda looking like a loner talking to myself
                        Re: HAZARD 2
                        lets try this
                          Re: HAZARD 2
                          YES
                          If you see what I see then It has worked!
                            Re: HAZARD 2
                            looks good!
                              Re: HAZARD 2
                              Thanks very much!
                              Its all made of 0.5mm titanium
                              Dunno what grade
